615 Loader PIN needed.
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: 615 Loader PIN needed.
    Posted: 11 May 2015 at 9:47pm
I'm missing number 6, any idea where I could find one?  Any idea what type of steel they used?
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 5:11pm
If the pin is an exact fractional size use 1040 TGP. If you do not have a steel supplier near you can buy short lengths on eBay. Find a person selling steel on eBay and "ask a question" if they can supply what you need. Alternately find a local machine shop. Look at a similar pin on your machine if it is not badly worn the type of steel is not critical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2015 at 6:20pm
Looks like that pin is a SHAFT running across loader frame to each side of loader arms .
It evidently is a structural part of loader frame and transfers stress .
 I would not worry so much about type of steel used but of bushings and fastening type used .
