Electric Tach problems - 7045
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Topic: Electric Tach problems - 7045
    Posted: 04 Apr 2010 at 8:15pm
The tach had been working just fine on my 7045, but we split the tractor to overhaul the engine and put new plates in the PowerDirector.  Now, that everything is back together, the tach doesnt work.  I was checking connections in the wiring with my dad in the cab watching the needle.  I accidentally shorted a wire to the ground, and the tach worked, but only when the wire was shorted.  I know I dont want to run it like that, so what does that tell me I need to do to fix it?  Thanks in advance.
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 9:30pm
 ONE OF THE TREE WIRES ON THE TACH IS GROUND. TERMINALS ARE MARKED .
WD,D17-S4,180,D21
This page was generated in 0.182 seconds.
