What kind of an impact wrench to buy
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: What kind of an impact wrench to buy
    Posted: 09 May 2015 at 6:52am
I like working on these crawlers. I have two 1/2 inch air impact wrenches. They just don't seem to be strong enough to remove the larger bolts. don't know what the rating is on mine but I suspect 250. I am thinking about buying one with more power. What do you all use. what power rating would you recommend so what would you all recommend. All comments welcome. Thanks Norm in Missouri
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 8:51am
Ingersoll Rand
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 9:04am
A co-worker bought a MAC (maybe Ingersol Rand  built?) several years ago. It would twist off a half inch grade 8 bolt with no problem. Our shop air ran at 140 PSI and he never throttled it back. He did replace the hammer once after a couple years of abuse.
 If you work on bigger stuff, you NEED bigger toys. Maybe 3/4 drive impact sockets and a 3/4 drive hammer Big smile
 The shop spline drive impact would need an overhead hoist for me to be able to run it today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 11:08am
SIOUX Air Tools- 1/2 " and for crawler work you need a 3/4 impact  minimum size for track and undercarriage work
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 11:17am
You should consider a torque multiplying wrench. The type I prefer is a handle with a gearset built in. You power the gear set with your ratchet wrench. With the torque multiplier in one hand and your ratchet in the other you can apply massive leverage on the bolt. If I remember they were made in Mass. They were advertized in "Rock and Dirt" Typically they had 25 to one leverage. You can compound them by driving a torque multiplier with another torque multiplier.
There are other types of torque multipliers but this is the type I prefer.
PS You can really break impact sockets and big bolts using a torque multiplier.
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 11:50am
go big or go home! ive used a 1 inch impact before on disk gangs and its crazy how much torque it has! would be perfect for those big old crawlers
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 12:58pm
Make sure, regardless of WHAT you do, that you have very low restriction in your air supply line. It takes pressure and volume to put the wrench in it's best performance zone... and don't think that just because a hose is big, that it flows well... I was using my wrench one day, and it started getting really weak... checked my compressor, and it was indicating just fine... figured there was something afoot with my wrench, so grabbed a different one, and it was a pooch too... then realized, checked hose for kinks (none found) switched to different hose, and bingo- worked great...
Problem was, that some spot INSIDE the hose, the hose liner had collapsed enough to restrict airflow.
Eventually, I cut the hose in half, put fittings on it, and checked to see which HALF flowed better... took the bad flowing half, cut it in half, and tested... eventually got down to the point where I had a six-foot section that wouldn't flow, the rest got made into short whips for other uses... that bad section I cut open for a look. Eventually the others will fail too, but they're still useful now.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 3:34pm
I've used Ingersoll rand my whole life, with very good success. And, yes Mac sells,or at least they used to, Ingersoll rand. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 3:47pm
I shouldn't pick on snap on tools, but when I used to work at an implement dealership, just about everyone had Ingersoll air impacts, cept for a new kid on the block, who had a snap on. One day this kid was taking something apart, and needed about four of us to help him. He had it down to one bolt holding it together, then rounded us up to help him. When he put his snap on impact wrench on this last bolt, it wouldn't budge it. One of the guys went and got his IR,and it zipped the bolt out like nothing, while we all laughed. That young man traded for an IR the very next chance he had. Otherwise, I like snap on tools, and I do think they have a better impact wrench now. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 9:10pm
I have an assortment of impact wrenches, from Snap On to Chicago Pneumatic(my oldest), I have a 3/4" Ingersoll and a CP 1" long shank like they use in truck tire shops. Biggest issue with any of them is air supply. 1/2" wrench 1/2" supply is fine, for my 1" I use a 3/4" ID air line that is fairly short from the supply tank, it all relates to a larger air motor needs more volume to feed it.
My compressor is a bit lacking, is a 60 gallon two cylinder single stage so I have to await replenishment to go again tearing into stubborn bolts with the big gun or the 3/4".
Lee (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 10:35pm
I have owned many 1/2 and 3/4" impacts. The IR's are hard to beat, a good value. My complaint with them is in cold weather the trigger freezes up and you cannot shut them down, LOL. In a shop not an Issue. Mac used to rebadge the IR guns but a few years back switched to AirCat composite guns, I have a 1/2 and a 3/4, these are animals. I use them most every day and run 150 PSI on my service truck @37cfm, and have never had any issues with them. If I remember correctly the 1/2 gun is around 750 ft lbs of torque, and the 3/4 is over 1K. I have removed many track pads from D8 & D9 dozers. Clean air, and daily oil is a MUST!. Northern Tool also sells AirCat guns and much cheaper than on the MAC truck. Torque multipliers are another story, at work we have a 55-1, it's 1/2 drive input and 1 1/2 output, I was tightening track frame bolts on a 1466 Koehring excavator years back and the 1 1/2 extension I was using let go, like a bomb went off, I was very lucky and was not hurt.
Lee
B212
912
Willy's Jeeps
Gleaner K
ksbowhunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowhunter Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2015 at 6:11am
2-37 WC
37 wf127
37 wf130
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2015 at 2:08pm
I got an older IR 2131 that's been good but I like bowhunters suggested 2135 model.Think mines only around 750 ft lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowhunter Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2015 at 4:43pm
I have had this impact for the last 12 years. When I was doing truck and tractor work it was used daily. I had no problems taking lug nuts off of a semi that a 1" impact sometimes wouldn't.
2-37 WC
37 wf127
37 wf130
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 5:39pm
I love SnapOn tools, except for there impacts they suck. MAC impacts are made by aircat which is an awesome impact
1968 D15D,1962 D19D
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2015 at 6:06pm
We use Ingersoll Rand impacts both at work and in the shop here. I believe the model number is a 2135I. I began buying them for aircraft brake removal @ Delta when they were first introduced. My co workers' son bought one to work at the Dart Trucking Company trailer shop. It is the envy of his co-workers. They are expensive, but they work.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
