Agco parts; owning oil seal numbers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Agco parts; owning oil seal numbers?
    Posted: 04 Apr 2010 at 6:58pm
Does Agco own the rights to certain oil seals ? I was replacing a 190 XT oil seal in the adapter plate ,tried to get it thru IBT, its a National seal, gave them the numbers and IBT said not avaliable ; but AGCO parts had no problem ;a trans shaft seal was no problem thru IBT , Im trying to get around AGCO all I can ; since no ORANGE, no support from me; was gonna buy all HESSTON hay equipment this year ; now NEW HOLLAND can make money off me cause thats the hay equipment Im getting !!
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 7:04pm
 special seals they do not have  we have a cross reference [19 80] that the dealers do not have in their computers unmless they still have the books
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 7:09pm
I know what you mean Doug.  I found the exact same thing when I restored the 420 JD.
If you are wanting just single lipped seals (but I haven't tried other type) I can call the motion Industries place here locally and give them the ID and OD and the seal wil be there the next morning.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 7:12pm
My friend is in the Power transmission business. Some seals, bearings, and belts are specialy made for certain manufacturers to their specs and therfore become propiety items. The seals, belts, and bearings on the same machine that happen to be standard industry sizes are available everywhere. Some manufacturers purposly use odd sizes to lock the customer into buying the parts from them.
