plowing
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: plowing
    Posted: 01 May 2015 at 1:45pm
thought i would get a photo plowing before i set the wheels out and get ready to furrow and cultivate     i will finish plowing with the 101 because the three point needs to be reworked to look better work better that plow 7" was made to work with the sears tractors             the plow onthe hudson is also sears 12" with frame biult around it          it dosnt  look like it but the wheel base on the two are the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2015 at 1:51pm
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2015 at 9:13am
That little steel wheeled tractor is about the cutest thing I've ever seen! - And usable on top of the cuteness.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2015 at 10:31am
thanks  i biult all of it hand made the wheels it has a rattle can paint job so it would fade fast   also there iis still a lot of little things to do it has a five speed going to a dodge rear end i am needing to get the brakes working better and the geometry isnot quit right on the cultivators but they do work good the 1941 briggs z runs real nice and looks  good in it        the 101 gets used for everything
This page was generated in 0.266 seconds.
