spin outs
jon p. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon p. Quote  Post ReplyReply Direct Link To This Post Topic: spin outs
    Posted: 03 Apr 2010 at 10:44pm
anyone know for sure if they quit making the 13-26 spinout rims? I was told they did also is $590 delivered to your door for two new 12-26 spinouts sound about right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 6:52am
Jon, every now and then you can find good used ones, but they aren't too easy.  My D15 came with 28" rear tires and rims from a WD/WD45.  I later found a set on ebay with ok tires on them, but the rims and wheel center were all good.  I think with shipping I got them for $350 so I was very happy.  If you're not in a hurry, you can do what I did, or find a set of 28" rear tires and centers to use, as they will bolt right on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon p. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 10:49am
So what rims will actually fit a d-15 series 11?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 11:11am
I too need to confirm this about the D15II; I have a nice D15IIP that I picked up that someone put new two position rims with 14-9-29 Stromel tires (Polish made) on and I was not able to get the original center rims with the tractor.
I have seen postings where it was stated that the WD45 rim centers will not bolt up to the D15II due to the bolt pattern and center hole being different.
Can anyone confirm if they have installed WD45 rims on the D15II?
Sure would make it easier to find rim centers as more WD45s were made than D15IIs.
If anyone can confirm the interchangeability, I could potentially hunt down WD45, D14 or D15 Series 1 rim centers/mounting flanges; I can always buy PAWs outer rims via many vendors.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 12:07pm
Wheel centers from a WD-45 or D-17 (28") will bolt onto a D-14/15. Both have the same 8 bolt mounting pattern. My understanding is the only 12" x 26 rims are available new. Allis and Oliver were the only ones to use 26" Power shifts as OEM equipment. 26" rims from a Gleaner A or E combine are often used as well , but are non power shift.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 7:31pm
  12x26 is as large as we can get at present  will check shipping an reply later  can may be get them to Elkart   you what too do then
bucksnortAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bucksnortAC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 7:49pm
i have a pair of 10x28 and a pair of 12x28 for sale with WD centers that would bolt right up.  the prices is $300 and $400 plus shipping.  i can generally ship bare rims for about $35 and all the spin hardware for $15, not sure on how much the center would cost.  i am in NE ohio and i travel alot, might be able to ship part way for free, contact me if interested.  buckagg@yahoo.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon p. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 9:32pm
did the d15 series 11 come standard w/ spinouts or could you also get regular type rears also?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 6:44am
Spin outs (Power Shift) rears were standard equipment.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 6:57am
I have a pair of 26" wheel center hdwe here if anyone needs it, may be going to scrap early next week, scrap prices are going up, expect alot of old skeleton's will be getting tossed into bin's for the ride to China.
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 7:08am
You can purchase new blank rims for around eighty bucks and weld your old rails inside, takes a little time but you end up with new power shift wheel. Fred
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 7:20am
Fred;  Where and who sells blank rims?  I would like to purchase a pair of 24" blank rims.     Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 7:37am
             Zurcher Tire  .260 692 6171  Monroe In.    Fred
