WD45 Diesel rebuild!
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Diesel rebuild!
    Posted: 03 Apr 2010 at 9:14pm
Maybe some of you guy's have senn this posting, but for those who haven't?,,,It's pretty nicely done!
Edited by LarryWC In - 03 Apr 2010 at 9:15pm
www.allischalmersmuseum.com
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 10:02pm
WOW Thats awesome great job Larry
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 11:33pm
That's not mine!!!! (I WISH it was!!!) but there are some VERY informative pictures with some explenations that are nicely done though.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 6:59am
Great Job ! The pictures are a great record and education for the rest of us.
AndyinWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 12:17pm
I would like to know where to get one of those brake pin pullers, anyone have an idea?
Andy
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 2:32pm
Thanks for the comments, that's mine and it was indeed a fun project.  I know I've said it before, but sometimes I think I spend more time propping stuff up for photos than I do working on things.  I also want people to know if it wasn't for the help of people that know these old machines the projects would be difficult at best, I try and post some of the stuff I've learned during the process.
My first machine was my grandpa's WC in 2004 and I had no real intention of restoring it, I just didn't want the barn to fall on it.  I must say first that I have been blessed with this hobby.  Every step where I didn't know what I'd do or how to proceed, I'd meet or be introduced to someone that did.  Being a computer network guy, I Googled Allis Chalmers and found Tony Carbaugh - he helped me out on several things and lined me up with others when he didn't have what I needed, and got me started on this forum.
One quick story comes to mind.  I needed a final drive hub for the WC - mine having teeth all chipped up.  I called Tony and he lined me up with Bill Deppe I called Bill on a Monday and on Thursday afternoon the back half of a WC was in my driveway all the way from Maquoketa, Iowa, and I only needed to pay some gas money for freight.  It turned out a brother of a co-worker of mine was coming through that way with a vehicle that could haul it.
I have had other very eventful coincidences too.  But this post will get too long.  The brake pin puller is made by Gary Agrimson http://www.agrimsontool.com/ac.htm
He also has been a great help to me, I don't hardly want to start naming people since I'm sure to forget some.  Dave Ferguson taught me everything I know about the WD45 Diesel injection system and should get named for sure though.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 3:47pm
So Tom,,,did you find the brake pin puller as effective as it looks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 5:11pm
Yes, it was very effective.  I pulled the ends off first though as I described on my web page.  I think I could do it better now that I know how though - well since I haven't had to in a couple years who knows.  You have to know that it has the ability to pull the ends straight off.  You have to make sure the shoes are loose and work them back and forth, I actually think the shoes were stuck to the pin more than the pin was stuck in the hole.  I could pound the pin in and get it to move out a bit prior to pulling the ends off.  Once that was the predicament I had to drill and tap a hole and get a washer ground to the right size to fit the tool again then spent more time working the shoes back and forth while pulling with the tool.  Many have said they have gotten them out with a little pry bar but some are so rusted in place you almost need to blast.  Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 5:42pm
Thanks Tom!,,I need to look into my WD's brakes and I messed with them last summer a little and the one I messed with wouldn't budge!
Dale Haymaker has told me several times,,,they'll either come right out!,,,,,or you'll fight them to the bitter end,,,,,,
What's your opinion of "neversiezeing" the pins before replacement?,,,Dale and I have talked about that possability too!
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 6:02pm
Great photos!!! I need to show this to my father.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 6:06pm
I put no sieze on my new pins.  I hope to never have to do a brake job on it again but maybe someone will appreciate it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 6:11pm
wow good job tom awesome pictures and good explanations
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 6:38pm
OK, Thanks Tom!,,,I'm with the same attitude too!
Hopefully not in my lifetime,,,but the next guy may be thankful!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 9:23pm
since when did a 45-d use shims in the rods and mains????
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 9:26pm
My uncle told me as soon as I bought my first 45, to leave a can of whatever penetrating oil you like in the tool box, and whenever you think of it give the pins a good shot.  then when you get around to it, they might just be freed up, especially if you are using the tractor and working the brakes.  It worked for me but i never checked them before I tried to remove them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 9:52pm
Michael,,I'd say that's probably good advice!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 11:01pm
Tom, I agree with all the others about a fantastic job of taking photos and sharing them with us, And a fantastic job of restoring the ole girl too. Thank you
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 10:00am
Tom
Thanks for the extra effort to take lots of photos during the rebuild process...and a special thanks for orrganizzing them and sharing them with us. I also use a lot of never-seize on bolts/pins when reassembing; great stuff for future tear downs...and to find out where your hands go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 10:12am
Yes, anti-sieze does seem to get on fingers and then leave traces where ever gets touched, and usually you need to touch lots of stuff before you can really clean them.
As to the shims mentioned, I don't know why there were shims under the rod bearings on the engine I purchased.  I suppose the idea was to tighten them up a bit.  Since the reason that engine had been sitting on the gravel floor of a shed for several years with no pan and head was because a rod bearing had spun, I can't think it was a good idea.  There were no shims on the mains just the rods.  In any case there are none in it now.
Thanks for the comments.  Tom
