616 Hydro |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: 616 HydroPosted: 03 Apr 2010 at 8:20pm |
Duetz-Allis 616 Hydro has begun to slow up speed wise (Ground speed).
Fluid level is OK, but probably need to change the fluid as it has been a while since the shop did it. Do these mowers have a hydro oil filter? Any ideas on what would cause it to move slow? Has to be flow related? |
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Posted: 03 Apr 2010 at 9:35pm |
Wear in the linkage could result in a slow decrease of speed. If you have a noticeable difference in a few days of use I'd look at the drive belt adjustment/wear.
If you do have a pump problem your likely better off finding a complete tranny and swap out rather than trying to dig into the hydro due to the clearances and possible contamination involved in a hydro.
Charlie175
Posted: 04 Apr 2010 at 6:21pm |
I will check that.
The manual doesn't say how much oil goes in it, do you know? |
Charlie
D-17_Dave
Posted: 04 Apr 2010 at 8:30pm |
I don't, however you can check out Simpltractors.com and post the question and I'm sure you'll get some more info.
