New Rake question
walterfd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walterfd Quote  Post ReplyReply Direct Link To This Post Topic: New Rake question
    Posted: 03 Apr 2010 at 4:30pm
Bought my first tractor a couple of years ago, a WD45. It has wide front end, starts, runs and looks good.  A couple of weeks ago I picked up an AC side discharge hay rake.
I didn't notice at the time (heat of the auction, buying more Orange and all!) that the rake has two hdro lines running to the pump that operates the rake.  I have only one line under the seat for rear attached equipment.  Did I waste my money or can I make modifications to power this rake with this '45?
JCinPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCinPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 5:06pm
So your saying your new rake is Hyd. not PTO powered.  I doubt that the high pressure low volume system on the WD45 will run this even if you do plumb a return line.  Hope someone with some experiance with hyd. motors offers some help on this.   JCinPA
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 8:29pm
you can go off your rear remote hook yo your implement and plumb you a return line into the belt pully bayonet bolt(remove the bolt and plumb your return line into it.works great
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 10:27pm
I'm kind a guessin that someone must have taken off the PTO drive on the rake, and replaced it with a hydraulic motor drive. In my own opinion, I don't think the wd 45 hydraulic system will run a hydraulic motor. Another thing that may have happened is that if it was a newer model ground driven rake, someone replaced the ground drive with the hydraulic system. Maybe you could change the rake back to the original type drive system.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 3:26pm
WD45 will run a hyd motor but just not with much power. Light loads are ok but I doubt it would pull hay rake duty.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 8:07pm
Buy a 175 to run the rake. LOL
Wink
I am a Russian Bot
