HD3 Loader
AC$$$$ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Topic: HD3 Loader
    Posted: 13 Apr 2015 at 2:49pm
I just purchased a 1969 AC HD3 loader and I have started to change all the filters and fluids. I replaced the air filter, the fuel filter, and the filter on the hydraulic tank, but I cannot find an engine oil filter. I looked in the manual and it shows the filter should be mounted on the side of the engine but it is not there. Can anyone help?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 9:55pm
Welcome to the forum! Does the engine in the picture look exactly like yours except for the filter? Wish you best with your new toy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 7:14am
Thank you for your response but I do not see a photo.
ivan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ivan Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 7:15am
We sell filter's can ship ups 989-379-2721
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 10:24am
Sorry for not clarifying that I meant the picture in your manual. I wondered if per off chance someone had put a different engine into your machine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 11:22am
I understand what you mean now, my bad. Yes the engine looks to be the same as all the photos I have seen, and it looks like it has been in the track loader for years. I cannot think of why someone would remove the filter assembly but I see no bracket, or lines capped off. I will start it and raise the bucket so I can get under it for a better look but from the top and side I see nothing that even resembles an oil filter. I had a thought that maybe because it was a track loader AC located the filter assembly somewhere else but I think I am grasping at straws. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 6:43pm
I assume it is a diesel engine from the D in HD3?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 8:11pm
HD3's could be diesel or gas.  Same motors as D-15 tractors...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 8:26pm
Yes it is a diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2015 at 10:34pm
Dave: Do you know if HD3's became the model name for both diesel and gas in a certain year or serial #? I had one with a 149 gas and it was called H3 (without the D) right on the front page of the manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2015 at 5:37am
Eric, you are right, I didn't read your post right, HD is diesel H is gas...
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2015 at 8:14am
The engine is a D-175. It uses as Wix P/N 51050, Fram PB50.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 10:05am
Thanks for the filter part numbers. I have yet to locate where the filter would be on my HD3 track loader. Unless it is remotely located somewhere other than the engine, it has been removed. I do not see any lines, or a filter bracket, and I am sure the manufacture did not produce it with no engine filter.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 12:43am
Could it be behind the engine or even under the floorboards?
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC$$$$ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 7:49am
I looked on the back side of the engine and could not find it but I did not look under the floorboards. I plan to lift the bucket and get under the loader this weekend to see what I can find. Thanks
This page was generated in 0.271 seconds.
