Potential Purchase: 7580 Black Belly, questions |
Page 12> |
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Topic: Potential Purchase: 7580 Black Belly, questionsPosted: 10 Apr 2015 at 7:37pm |
Hey all,
Our friend the tractor broker is currently en route to our place as we speak with a 7580 black belly, (to stay the night, or the rest of its life, our choice. :) ) I had a few questions: The power director doesnt work in high, but holds fine in low. The oil levels were fine. What could be wrong? Any possibilites its just in the linkage? Second, it has a dipstick in the front diff, but it also has some lines going to and from the front diff. Is this a recirculating system like a JD 8x40-8x50 4wd? what year did they go to this setup? (our friend has a 7580 that he is keeping, and his does not have this) It bleeds back fuel something terrible, have to bleed it every time you start it. What is the line setup on these? Is it best to start from scratch and put all new on? It has the lift pump, IDK if its factory or field installed. (wasn't it 1981 they put the LP on factory?) Overall it sounds decent, and he wants less than 5K for it. it is long axle, 9 bolt duals, 3pt, PTO, and IIRC 3 remotes. Any input appreciated, thanks! Edited by GM Guy - 10 Apr 2015 at 7:38pm |
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 10 Apr 2015 at 8:41pm |
He is a broker and he is asking for less than 5? In theory he would be making money in that deal as well. Wonder how much be bought it for? Seems awful cheap for something that size. I'd be a little skeptical, but that's just me...
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 10 Apr 2015 at 9:21pm |
i'd sure jump on it! and wouldn't worry about the PD since it works on the low side unless you have a lot of road travel! my 7080 was good only on the high side, and didn't bother me disking with it that way! would have preferred it good on the low side tho as I don't have much road travel! can't go wrong with any 4x4 for $5000. yer a lucky bugger! black fuel...sounds like it had/has soybean fuel in it! may hafta clean out the fuel tank and lines good.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 10 Apr 2015 at 9:40pm |
I'd go for it. Darrel
GM Guy
Posted: 10 Apr 2015 at 9:54pm |
He is making money on the deal, but not tons. I think he bought it for under 3, (doubt under 2, but who knows) and is pricing it to us for slightly under 4 and is keeping the factory top link and quick hitch for his 7580. His has been a John Deere only guy for years, but we have talked him into keeping the 7580 and 8550 he picked up recently, so I think he caught the fever. :) We have bought more than 10 tractors from him, and what he says is just whatever the farmer told him, really nice guy that we have dealt with for years. Like a consignment sale, he only knows what the farmer told him, so if the farmer doesnt mention anything about a certain problem, he wouldnt know either. |
GM Guy
Posted: 10 Apr 2015 at 9:56pm |
Bleeds back fuel, shameless, no black fuel! :) How long did you run the 7080 with no low side? did you buy it that way? As long as we dont hurt anything running it as-is, we may buy it and run it. If it will grenade, we might let it pass. |
GM Guy
Posted: 13 Apr 2015 at 2:35am |
Bump. Our buddy wants us to make a decision.
Another scenario has popped up, Mom offered to give me a low interest loan if I wanted it, as the folks aren't overly interested in it due to the wore out tires. IIRC, over a grand has been dumped in the A/C, new Sanden compressor with manufactured bracket (conversion kit I have seen before) new receiver dryer, etc. I am mostly looking for responses on the high side of the PD being out, that is what concerns me most. Thanks! |
Adam Stratton
Posted: 13 Apr 2015 at 8:02am |
We run one and I would probably buy the one you are describing at that price. Ours has a lift pump on it and has ever since we got it. There is something different (im not an expert) about the advance on those bigger inj. pumps, and we had problems with ours getting messed up and not starting well several times. It might not be a bleeding issue, but an advance in the pump issue. Either one, once its running I dont think it hurts much. Check for slack in the drive lines. One drives the rear axle and one drives the hydraulics, so it is running all the time. They can get floppy and are $$$ to fix. The shifter linkage for high to low is different than the other tractors we have, so that could be part of the problem, but I doubt it. The cables are running a LONG way compared to other 7000 series tractors, so a little slack multiplied by that distance COULD make a difference, but I wouldnt bet lets on it. Look at the mph chart and see how often you would use the high side (other than roading it), and see how much it matters to you. I really have no idea how much fixing it right would cost, because we have never had to do one. With the way we run our 7580, I would probably not worry much about it if it was in my neck of the woods.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 13 Apr 2015 at 8:54am |
I don't know enough about the different scenerios on "high side not working"to advise what's going on and don't know how the tractor is built to know how hard it is to work on but,I know that working on the PD itself isn't a rocket science job.On my 8070 I had it split at the flywheel and could get right to it.Kinda heavy and some lifting equipment and extra help makes it easier.Must have a manual to check all the demensions in the "stack"for clearance between PD and trans but you can handle it especially if some fool hasn't been in there and shimmed it wrong to begin with. The PD itself is just 2 large clutch packs.It may have just lost a piston seal and fried the clutch.New parts aren't cheap but are available.At least there are less plates in the high side!LOL!The factory manual is very detailed and good as far as what and how.If you can remove the whole front end away from trans hsg it wouldn't be too bad but if you have to work inside frame rails it will be more "fun".You need to talk to DrAllis or someone to find out how to run pressure test before you do anything.If your not a gambling man with a sense of adventure,you may just want to pass.
SHAMELESS
Posted: 13 Apr 2015 at 11:58am |
Bob...I bought the 7080 that way, didn't know it was out when I bought it, and when I went to drive it home 40 miles...I was on the high side anyway! found out it didn't have a low side when I hooked up to my disk! so I tried the high side and it worked fine! used it that way for years! even when I was ripping with 7 shanks. 1st gear on the high side worked fine! plenty of power there! like I said...if you don't have a lot of road travel, the low side should last along time! shucks....with 8 tires hitting the ground and the weight, it should pull a lot that way unless you have extremely wide equipment!
SHAMELESS
Posted: 13 Apr 2015 at 12:09pm |
heck...if you think you need the tranny fixed right away, or if you can wait with it, maybe you'll find another one (whole) that you can change out later on! nothing wrong with having a parts unit! nowadays that's about what is needed no matter what color! buy a new combine and another new one for parts! new tractors and combines are designed now not to last like the older stuff did!
GM Guy
Posted: 13 Apr 2015 at 3:09pm |
More info.
He said the oil level was fine, but maybe he added some oil and it read full and he though all was well, irregardless, the transmission is a little bit below add. could this be part of the issue of no high on the PD? It is serial number 2866 which makes it a final year, 1981, which is allways a good thing, many updates are factory installed, including the lift pump. The top driveline that runs all the time for hydraulics does have a wobble to it (I assume the slip joint is wearing out) It runs true up front, but you look back into the frame, and it is wobbling. Plenty of hyd. leaks The PTO does kick on and off The Tires are 18.4x38. It does have one almost new BKT bias, one fairly new GY Dyna Torque II bias, one crappy 30 percent bias, and the other 5 are 5-15 percent Goodyear Dynatorque radials. No calcium, double bevel wheels on cast centers inside, and 9 bolt duals with reinforcing plates outside. a few small cracks around the upper hinge of the door, nothing broke loose yet, so should be easily repairable. no radio, needs a cab kit and a lower cushion. front window cracked from a hail storm, mirrors cracked as well. Overall, I am thinking that the problem is isolated to the PD clutch itself, so the trans. and drop box should be ok, and the engine sounds great, very little blowby, and it drove 35-40 miles to get here, so I am leaning toward buying it unless swayed otherwise. |
Jwmac7060
Posted: 13 Apr 2015 at 3:14pm |
I owned a 7580 and personally would stay away from it even at 5 grand. Ours was a money pit and I love Allis tractors....
GM Guy
Posted: 13 Apr 2015 at 7:16pm |
Keep in mind we likely wouldnt use it to its advertised capacity, just babying it along with implements we use behind a 7060. (23 or 25 foot blade plows, 22 foot 760 IH offset, maybe up to a 24 foot wing fold Krause offset) Now a 7580 basically has a 7080 transmission hooked to (2) 7040 2 pinion equipped differentials, correct? do the 2 pinions hold up fine in a 4wd? I know a forum member showed pics of a hard pulling 8030 that had cut a groove around the carrier with the 2 pinion. |
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 13 Apr 2015 at 8:09pm |
If you end up getting it, either have the injection pump set to the 4W-220 specs or operate the engine with a reduced throttle setting (2400 rpm full load or about 2500 rpm high idle). The engine will thank you. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Jwmac7060
Posted: 13 Apr 2015 at 8:30pm |
GM...you do what you want but we never overloaded our 7580 in my opinion. 9 shank chisel plow, 24 ft field cultivator, and an 18 ft tilloll. It looks like an absolute beast but looks can be deceiving. That tractor was the weakest sorriest excuse for an Allis we ever had on the farm...if the drive line already has slop in the one you are looking at be prepared to replace them all. You say low on the PD is out...be prepared to replace that as well as the torque limiter. I'm quite sure we replaced every hydraulic line on ours and without fail we would still get a leak somewhere. The 7580 motor is a different animal than your 7060.We could over work our 60 and I never feared it would grenade on me and it never has. The 7580 on the other hand we always tried to baby and without fail we couldn't keep bearings in the bottom of it....unfortunately the last incident involved driving it down the road at 2100 rpms and the crank broke and chucked a hole in the side of the block....we put two sets of bearings in it in a 6 year time period,new hinge pins,countless hydraulic lines,ring and pinion and a drop box in it..also dropped an injector tip down on the number 4 piston. So you can see why I would never own another 7580 if it were given to me...save yourself some time and money and just buy another 7060...you'll be happier in the long run
SHAMELESS
Posted: 14 Apr 2015 at 12:30am |
i'd love to hook up to my 2500 disk and have my head up in the clouds on that 7580! it would be so much fun to drive! kinda the feeling when ya first fell in love with a gal!
GM Guy
Posted: 15 Apr 2015 at 12:53am |
GM Guy
Posted: 15 Apr 2015 at 12:59am |
So, what does everyone think of the new purchase? :)
Cut the check today. Out here it isnt unheard of, but long axles are none too common on a 7580 from what I have seen. Unfortunately the QH and top link pictured dont go with the tractor, buddy is keeping them for his 7580. Its definitely a fixer upper, but for under 4 grand, and it drove here 30 miles from the POs place. The last pic shows the best tires. luckily all 8 rims are perfect, dont see that often! So, good decision or bad, its mine now. (kinda, need to get to work to pay off the loanshark, aka mom. :) ) |
SHAMELESS
Posted: 15 Apr 2015 at 2:42am |
in think you did great! you'll have plenty of traction on those tires for years! go play with it awhile before deciding what you want to do with it and what you want to fix on it! you'll learn to love it better that way! (it's a mind thing), can't touch these under $6000 here!
SHAMELESS
Posted: 15 Apr 2015 at 2:43am |
I wanna drive it!
JPG AUSTRALIA
Posted: 15 Apr 2015 at 6:43am |
You did good ,glad you screwed him down a bit,people always rate the tyres by the tread left ,thats not as important as the casing ,no cracks in them is the main thing. Have fun with it and enjoy yourself.
SHAMELESS
Posted: 15 Apr 2015 at 8:06am |
if ya don't like it, you could probably part it out for bouts $15,000 more or less!
GM Guy
Posted: 15 Apr 2015 at 9:57am |
very few part-outs shameless, we are a no kill shelter so far when it comes to tractors. Now with combines, if its super tacky or a variable belt drive, it usually dies so others can live on. ;)
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 17 Apr 2015 at 1:52am |
Looks like the twin of mine. Price was right too. I bought mine for $1900. but spend another $3,000 fixing it up, (drive shafts, (thanks to Redline), Turbo, Hydraulic pump parts, PTO drive shaft in rear end, etc. etc.) Don't use it much but fun to play with.
Allis Express participant |
LB0442
Posted: 17 Apr 2015 at 8:48am |
Looks great, you got into it for the right price. I have always liked the look of the big articulated 4wd. I am glad it's not in a savage yard, good to see the big orange live on.
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 811 |
Posted: 17 Apr 2015 at 10:23am |
Check the tractor for fluid in the tires, everyone I have seen the tractors are loaded for bear, and not sure why its a small cu in engine that had power complaints so lets make it even heavier requiring more power!!
Also I can tell you the tractors are unbalanced the way they come from the factory, doing field work they do not achieve a 50/50 split, and I believe thats is what causes the driveline and drop box problems, to get a proper balance you have to actually put fluid in the rear tires and leave it out of the front, which contradicts what I stated above, but you cant remove weight from the front, so thats your only choice, and if your tractor is empty, its way out of balance. We have 4 pad scales we used to balance ours, with 18.4-42 filled on the back it comes out almost exact for the front to back split, and the side to side is almost pefect. It made a huge difference in its ability in the field. Our Steiger was the opposite, that needed a huge rack of weights on the front to make the split right.
LB0442
Posted: 17 Apr 2015 at 11:19am |
Kcgrain, thanks for posting that. I am still working on my 7580 but I know the tires are loaded. It's the first one of these I have had.
427435
Posted: 17 Apr 2015 at 1:04pm |
Sitting still on a scale, you should have more weight on the front axle. How much more depends on what field speed you're running at. Pulling hard at 4-4.5 mph, you should have 60-65% on the front axle when parked. Less if you're running faster. However, you are correct in that too much weight really degrades the tractor's performance. With empty duals (cast centers) and no weights, the 7580 weighs over 23,000 lbs already. Edited by 427435 - 17 Apr 2015 at 1:05pm |
Mark
GM Guy
Posted: 17 Apr 2015 at 1:33pm |
Thanks for all the encouragement guys!
As far as rolling stock, luckily its completely dry, and looks like its been that way since new, no residue anywhere. cant believe there isnt a single bend or cut in the rims, all 8 are perfect in every way. It isn't overly heavy either, cast centers on double bevel rims inside, and 9 bolt pressed steel duals outer. If we need to add weight, I plan on using a common method guys use on New Ag Talk, make up a weight bracket using front end weights so you can put it on the 3 point hitch for quick and easy ballasting for drawbar applications. Mark has it right, you have to have it heavy on the front static ( I have heard as much as 65/35) and as it pulls it will weight transfer to the back to achieve 50/50 split under load. |
Page 12> |
