AC 6060 Fuel Pump
Bill H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill H Quote  Post ReplyReply Direct Link To This Post Topic: AC 6060 Fuel Pump
    Posted: 02 Apr 2010 at 8:47am
Cousin has an AC 6060 with Roosa-Master fuel pump. Tractor will idle , but cannot be accelerate. Local technician is tied up with full-time farm clients. Any thoughts on the problem?
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 9:08am
Take the fuel line off at the pump and see if you are getting fuel at the pump.
"Burgie"
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 9:46am
another classic symtom of a broken flex ring in a Roosa. take out the return fitting(top of pump), clean out all the particles, and make sure the ball can move. put it back in, this will get you a little time till you can fix it right. Alot of guys say just knock out the ball, and now its fixed, WRONG! The plugged return is just the by product of the real problem, a pre-warning sign. try running it with the timing window screws loosened. good luck, Ed.
This page was generated in 0.049 seconds.
