Seal kit needed, I600 steering cylinder.
vooodooo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vooodooo Quote  Post ReplyReply Direct Link To This Post Topic: Seal kit needed, I600 steering cylinder.
    Posted: 05 Apr 2015 at 6:48pm
My steering ram leaks badly.
I am looking for a seal kit, and some advice on how do it.
On a positive note, the gasser engine was running like poop. Bad spark intermittent. Just for piece of mind I did a compression test. 135 on all four.
Did a pertronic swap for the points, changed plugs, coil, wires, cap and she runs like a champ.
It runs so well I haven't even bothered to time it.
Edited by vooodooo - 05 Apr 2015 at 7:11pm
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 12:48pm
If you have a good local hydraulic shop they should be able to get the right seals for your power steering ram. Sounds like you got it running good. I have found every time I put in a Pertronix kit I have to advance the timing to get it right.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2015 at 6:50pm
Ditto to Eric.  Take the cylinder to a good hydraulic shop.  They will take care of it.
This page was generated in 0.178 seconds.
