Pull at Frederick Md
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Topic: Pull at Frederick Md
    Posted: 03 Apr 2015 at 6:31pm
The local Green tractor store is having their Spring pull on May 3rd. You should be able to find details at  www.gladhilltractor.com.  I plan on getting there with my 2 CA's. It's about the only place locally that will allow me to pull my turbocharged CA.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 5:55am
Good Luck Paul!
Make a video of the pull for us.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 9:24am
Charlie: How about coming and bringing some ORANGE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2015 at 6:55pm
Little far for me!
Charlie
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2015 at 8:11am
PaulB,
I would definitely like to hear about how you do with the T/CA. If they would allow a 2500 class at Tunica I would make the haul to compete. Our CA does real well in 2.5/3K classes.
I don't want all the particulars, but what motor did you use for the T application?
May the orange be with you!
 good luck in MAY.
dgerth
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2015 at 11:14am
Of the few ORANGE tractors that showed up we dominated what we ran in. Our class was 3000 open, a bit outclassed for the two CAs. The non-turbo CA was the test puller and after a number of false starts because of the sled malfunctioning, it won the class by an impressive lead. Second place was a local good running big cube WC. I took third spot inches behind the WC with the turbo CA. Balance was my downfall. If I had gotten the test runs like the other CA things would have been different, that's for another day. The local hot Farmall H was a dismal 4th followed by a couple 66 Olivers and a Farmall B that could barely move the sled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2015 at 10:46am
https://www.youtube.com/watch?v=-buNl2ZVwk4
This is a video from the pull
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2015 at 11:07am
Thanks Paul, that was neat
Charlie
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2015 at 7:28pm
Looks like the whole video was done by a drone. In one segment you can see the drone's shadow in the video.
Here is a clickable link:
This page was generated in 0.227 seconds.
