170 Gas Will Not Start
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Topic: 170 Gas Will Not Start
    Posted: 03 Apr 2015 at 10:50am
I bought this 170 with a stuck engine. I have since freed the engine and completely refurbished the fuel tank and carb. There is free flowing fuel to the carb and the bowl fills. I have spark on all plugs. However, I cannot get the thing to fire not even on starting fluid. What's the problem? The engine only has 2,100 hrs on it. What am I missing?
-Slim
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 10:58am
Have you had the valve cover off and looked at the valves? What is the compression on each cylinder? Sounds like it won't draw fuel mixture into cylinder. What did you do to free up the engine? Tracy
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 11:10am
I haven't had the valve cover off. That's a good idea. I'll do that next. I haven't checked compression. Probably a good idea to do that as well. As for freeing up the engine, I soaked the cylinders with Marvel Mystery Oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 12:09pm
COMPRESSION TEST !!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 12:28pm
If that is all you done, you will find the compression test really low I bet. If an engine is stuck that it takes more than a little effort to free. I would at least pull the valve cover and look, most of the time get the head off as well. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 3:14pm
...check your firing order making sure to know distributor rotation.Stuck engine often means stuck rings too.
Slim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slim Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2015 at 6:41pm
It runs!!! Finally. The problem was bad spark plugs. Now all I have to do is free the clutch up.
-Slim
This page was generated in 0.077 seconds.
