allis Big Ten Questions
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: allis Big Ten Questions
    Posted: 03 Apr 2015 at 9:08am
Is  this series of tractors  considered  garden tractors or Lawn tractors  ?
Any suggestions before i replace the head gasket on my  Big  Ten, looks like it is leaking ?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 9:42am
They are Garden Tractors. As you can get a full line of garden tools to fit them. As for head gkt. Just clean and blow off all dirt and grass before removing. Then you can clean carbon off head and have head surface machined or We use a long 1 1/2- 2'' wide flat fine tooth file and go across both sides at same time. You need it perfectly flat! If you need bolt sequence and torque, I can get them for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 10:43am
Yeah, Jeff is spot on about the flatness! Two things. Clean, n' flat!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 3:41pm
Yes, bolt pattern and torque specs please.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 11:10am
190 inch pounds or you can do as text says.
