New engine for the 45
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: New engine for the 45
    Posted: 30 Mar 2015 at 12:18pm
I've been working on rebuilding an engine for my 45 for quite a while now. The one in it still runs great but leaks oil like a sieve. My plan is to pull it and replace then do a rear-main, pan gasket, front seal job on it.
Thought I would post some pics of the progress. A shot of the block after hot-tank. Wasn't real impressed with the lack of cleaning.
I wound up having to use a WD block. couple shots after I finished the clean-up.
Here's a shot of the crank going in. This was quite a process. The block had no shims in it. I thought, cool, been line-bored. Wrong, just had all the shims removed. Spent a coupe of weeks making shims and measuring to get where I was happy with the clearance.
The rotating assembly finally together.
Being a WD block, the main bolts were lock-wired. I worried about this for quite a while then decided to just buy some pliers and wire and learn to do it.
Not as good as the guys on U-tube but a whole lot better than what I found when I pulled the pan. Made a few 'bones' learning the process.
Oil pump and timing cover on.
That's all for now. Will update as I make progress, Mike.
1terrygladys View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1terrygladys Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 12:36pm
Thanks for your pictures.  I'm impressed.
Terry
WD-45, WD, Unstyled WC, SC Disk, JD 4430D, JD 4010D, JD B, Iowa pastor & disciple of Jesus Christ
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 1:39pm
The engine you are rebuilding, is it a WD or a WD45?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 2:21pm
I don't have a lot of knowledge about the difference between WC, WD, WD45 blocks. I was under the impression that the block I have with the side plate over the pushrods was a WC only. I would guess that the internals are interchangeable????
Very nice clean job. It looks like you have covered the details. Nice clear pictures also.
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 2:43pm
nope, WD's had pushrod covers on the side of the block too. WD-45's didnt
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 3:02pm
Thanks guys. It is a 45, everything but the block. The 45 block I have is not good. The sleeve standout was all over the place. I haven't junked that block yet but probably will. Wanted to get the motor done in time to change it this spring. I had a tired wd motor so decided to use the block. Looking for another 45 block would have set me back at least a few weeks.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 7:15pm
Looks like you are going at it the right way, keep up the good work. I don't understand all the broken wire. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 7:28pm
Nice job.  What did you do to clean up that block after it came out the first time?  Looks really good!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 7:52pm
like the aircraft safety job,had to have a pair of safety wire twisters.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 12:51am
Don, not broken. Just not happy with the fit so I cut it off and tried again until I was satisfied. Yes the safety wire twisting pliers make quick work of the process.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 6:34am
Nice job !! Better to go slow and get it right the first time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 8:22am
Ted, I just wire brushed and scraped with a putty knife. A 4 inch electric and a die grinder did most of the work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 1:27pm
I will try to keep this updated through the process. I am ready to put the pan on now, Thanks to Don for the demo and video. Without that it would have been interesting trying to get it sealed up. Still could be but I feel like I've got a fighting chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 5:20pm
Did you change the cam bearings too.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 8:08pm
Thanks for sharing the pictures.
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 8:13pm
Very nice job.  Thanks for sharing the pictures and comments.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 12:57am
Yes, new cam bearings. When I started on this, i didn't really set a budget. Probably a good thing. Got some pics of the head I will post soon. I think the only things that are not new is the casting and the valve springs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 12:35pm
The pan is finally on. Been a little apprehensive about this, fingers crossed she seals up.
Up-rite and headed in the right direction.
There have been several people who helped a lot with this project. Thanks to Don and Rick from Mo. and Reede at the Central Ia. Farm Store. I bought the crank from Rick and got a nice clutch set-up from him too. Pics of that later, Mike.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 4:54pm
Made a little progress today. Got the head and plate on. Had to interrupt the fun to rebuild corn meters for the planter. Hopefully be planting corn in a couple weeks. Here's a couple shots of the head back from the machine shop.
And finally bolted down.
I feel like I'm getting close, won't be long and paint will start flying. Not my strongest suit. Hopefully it will look ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 5:14pm
Mike you might turn the oil filter housing over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 10:30pm
Thanks Don, I might have caught that before it goes in the tractor. At least I hope I would have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 10:08am
Mike you are doing a good rebuilding the WD/WD45 engine that it's hard to find stuff to pic on you. lol kip up the good work and post more pics.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 10:33am
Nice work Mike. You are doing great.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 8:16pm
Thanks, I've got some more pics and will take more as I progress. Got the oil filter situation straightened out today but that was all. Had to go to the farm and get the planter ready to go. This spring has been a lot better than last year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2015 at 10:54pm
Are there any secrets to get that oil filter housing sealed?  I think all of mine leak.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2015 at 9:03am
Yes, they all leak.
From what I've experienced, I see two major issues:
1 Cork gasket shot
2 Aluminum base warped from someone overtightening the bolts trying to accomodate #1.
Worst one I had was warped bad enough that I had to take it off, get it really, really clean. Then I filled the voids on the back side with hard-setting epoxy, then milled the face flat, then reinstalled it onto the tractor with a gasket I made out of neoprene gasket material. It doesn't leak... yet...
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2015 at 12:52pm
Time for a little update.
I had quite a time with the rocker arms. Tip for anyone else doing this, head, rocker-arm support stand, stud, and valve cover are all specific to 3 or 4 inch head. This engine has the four inch head from a 45, the wd engine I got the block from had the three inch. Long story short, I spent a lot of time getting all the parts to match.
Here's one of my time killers. Had the wrong valve cover ready for paint. The right one wasn't.
I had one adjusting screw that wouldn't turn. Did a total tear down to change it, put new corks in while apart.
Just about ready for paint.
When I installed the governor spring and cover I discovered I had plumed the oil lines incorrectly. Got that straightened out and masked everything off.
The primer laid down real nice.
Since I had the tall valve cover naked, went ahead and primed it too. Thought about painting it but not sure if I will use it or sell it. Can always paint later.
And painted, three coats of pure misery for me. If I ever learn how to paint without runs I will be one happy guy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2015 at 12:56pm
I missed the shot of the two valve covers. Probably spent two hours cleaning that thing prepping for paint.
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2015 at 1:05pm
What ended up happening to the other block? Was it any good?
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2015 at 1:18pm
While I have the tractor apart I,m going to replace the hand clutch. Upgrading to a three disc. Got a NOS spring (with red stripe) and the unit off e-bay.
I set this up according to the manual, clearance checked right on when done. Hopefully I don't have to adjust it after installation.
Also have a freshly surfaced flywheel, new ring gear, (real bargain on e-bay) and 9 spring clutch and pressure plate from Rick.
Thought I had a pic of the clutch but can't find it. Found it.
Edited by IBWD MIke - 19 Apr 2015 at 1:28pm
This page was generated in 0.680 seconds.
