Grader model D
markmc60 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Topic: Grader model D
    Posted: 30 Mar 2015 at 6:50am
The engine/head were rebuilt and was never reassembled.
I have a few buckets of bolts and parts. I will have to hone off the surface
Of the cylinders and turn it over.
I need info on which is the best manual for engine reassembly
Where fo I get it?
What is the best way to get the studs out if the block and head.
I have a few pictures. Just not sure how to upload them right now
I will load them to photobucket sometime today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 8:31am
Agco manual for the WD and WD 45 would be the best, IMHO.
Stud remover should get them out, or vice grips, close to the bottom of stud.  If they are real tight heat with propane torch, to about 250 F and melt a beeswax candle against the bottom threads, let cool, and try again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 9:18am
see if this works
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 9:22am
d model
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 9:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 9:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 9:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 6:16pm
Originally posted by markmc60 markmc60 wrote:
See the square area, on the frame rail, above where you step up to get in? (in this photo)
That is where the grader serial number should be.  the number you chalked is the motor serial number.  Other than it being a gas motor, it doesn't say much about year, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 7:10pm
Can someone tell me the year of this unit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 7:11pm
There is the 180-15 stamped in the frame
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 7:51pm
The data plate appears to be installed on the right side of the operators station on the outside of the enclosure. (Black plate) There will be a D number on the plate . With that number we can determine the year. Ours is a 1956, Serial D-4997.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 7:59am
ohhh you mean this spot here...... yeah, not there.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 9:46am
Engine Serial No. is 1949 era.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 10:12am
thanks Gary, I am going to put it all back together one way or the other. just thought it would be nice to see what year the grader is. round frame and tilt front wheels, that might help me isolate it.
again, thanks to everyone for the input.
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 11:36am
Hi Mark.    I would assume that this grader would be from the early 1950's: WD engine, no hydraulic turn mech. for the rotation of the blade and a smaller gas tank. What is interesting is that it appears to have the tilt mech. on the front wheels.   Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 4:55pm
In looking at the parts book, the machine upgrades took place after serial 3370. This would include the WD-45 engine, improved wheel lean as there was also a mod to the moldboard  which shows a welded and non welded mounting ball prior to serial number 2477. After  2477 the ball on the circle arm would have been welded rather than a separate part. 2477 to 3370 serial range would make it a 52-53 vintage.
Curt Anderson
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 8:28pm
Mark, look on top of the hydraulic control box. See if there's a plate on there with some numbers.
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 5:49am
Good morning.   There should be a I.D. plate on the hydraulic pump also.( the pump is driven off of the crankshaft pulleys at the rear of the grader. ).   Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 8:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 8:11am
these are the numbers on the plate at the Hyd. control
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 8:19am
by the looks of the ball of the blade in this picture it is bolted on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 8:36am
A picture of the rad grill might help nail down the year, if you have the grill, that is...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 9:06am
   You might try to remove some of the paint on this tag in order to see if there is some additional information under the paint. Careful, these tags may be aluminum and hard to clean so that you do not erase any information that may exist.   Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markmc60 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 11:20am
I think I have the grill, I will look in the pile of stuff, and thanks for the info.
you folks are very helpful and I thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 8:15pm
Ross I think you're right about it being early 50's. But the tilt steering I didn't think was available till after 55.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 8:28pm
     i cant belive its hydralic my neighbor has a i think md100 it has gear boxes its alot newer than that          by the way thats a neet little patrol
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 8:59pm
no it doesnt make sense,  all the big graders were mechanical control long after D was using hydraulic control
This page was generated in 1.807 seconds.
