AC C final drive seals
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: AC C final drive seals
    Posted: 28 Mar 2015 at 6:50pm
Question about the pinion axle seals.  According to the parts manual, there are two oil seals--an inner and outer.  I see the inner seal just behind the bearing near the brake drum, but I don't see where that other seal goes.  Mine sure didn't have one that I could see and I don't see a place to actually put it.  Help please.
Steve79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve79 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2015 at 8:53pm
The other is in the main body of the tractor.  On the inside of the bearing retainer.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2015 at 9:09pm
Thank you.  I see it in the differential bearing retainer.  Appreciate the help.
