WF steering wheel
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Topic: WF steering wheel
    Posted: 31 Mar 2010 at 7:45pm
Working on wf and need steering wheel. This wheel is not like any other allis I have. The book shows a cast hub. The one I have has steel hub with a recess for the steering post Anybody replace the black covering on outside ring? Or maybe a new wheel. Thanks Henry 620 439 5638.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 7:52pm
Minnkota Repair will fix a steering wheel. I know the WF has a different wheel but don't have a good picture of one.
 http://minnkotarepair.com/
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 9:01pm
i agree, i had minnkota rebuild mine, a really nice job. I have seen the larger hub in pictures, never on a tractor. the diameter is different than b etc as well as wc etc.  Also it attaches with a key and nut not a pin like my wc's. good luck.
Doug R MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug R MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 11:14pm
Are you guys sure that Minkota is still in business? I thought they hung it up awhile back. I do have a WF steering wheel but I should take a closer look at it to see what it needs. I may need to do a little straightening and welding and then it would need a Minkota job if they are still doing this. It will be for sale but it wont be cheap cuz WFs are scarce enough as it is let alone just the steering wheel. Let you know tomorrow.
Doug
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 11:17pm
Doug: I believe they are still advertising in the magazines.   Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug R MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 11:36pm
It sure enough seems so. Maybe I just dreamed it.
Doug
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 9:03am
DOUG--- I have ever thing on hold waiting for a price and condition on your wf wheel !    Henry
