d-15
jon p. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon p. Quote  Post ReplyReply Direct Link To This Post Topic: d-15
    Posted: 31 Mar 2010 at 1:29pm
where would the remote hydraulic be operated from on the d-15?any help would be appreciated
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 1:58pm
If there is only 1 remote it is operated by the top lever on the left hand side just under the steering wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 1:59pm
Which will also operate the lift arms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon p. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 2:01pm
thank you i was confused there seems to be a lever on top of the tourqe housing that has nothing hooked to it cant figure out what its for
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 2:08pm
If it is the leaver under the gas tank, it is for the belt pulley that would mount on the right hand side of the tractor where the round plate is. There is a leaver that attached to what you are seeing so that you could engage the belt pulley. If you do not have a belt pulley you probably don't have all the linkage
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon p. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 2:10pm
i really thank you for your time ..i just bought the tractor think i got a great deal d-15 series 2 for 12 hundred just know what i have read
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 4:35pm
Sounds like a good deal, is it possible to post a picture. Fred
This page was generated in 0.238 seconds.
