912 6 speed raking gears
Hubcap View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubcap Quote  Post ReplyReply Direct Link To This Post Topic: 912 6 speed raking gears
    Posted: 22 Mar 2015 at 9:28pm
I removed the back plate to the gear box and drained the oil put in fresh gear oil even adjusted the clutch but it still rakes gears not every time but its intermittent. 2nd and reverse gear are the gears that rake.
I opened the seat to watch pulleys when clutch is engaged and the front pulleys keep turning and the rear pulleys are stopped when clutch is engaged.
Is it a normal thing to get an occasional grind on these machines or should the gears mesh up smoothly ? Otherwise than that the tractor runs like a raped ape.
Any feedback tricks tips ect will be appreciated..... service manual would be awesome
like a pdf file. Thank you
This page was generated in 0.223 seconds.
