Addiction |
A-Cvtx
Topic: AddictionPosted: 19 Mar 2015 at 8:44pm |
Bought this little jewel from Illinois. I need to pick it up and get her home!!
Insanity is relative. All of my relatives are crazy!
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 19 Mar 2015 at 10:02pm |
Now there's attitude right there! My kinda Tractor. Looks like its sportin' a set of 26x12x12's out back. Nice snow blower. Looks like she's ready to work. Good luck with her. Looks great!! Love them 700 series to!
Steve@B&B |
Dgrader
Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
Posted: 19 Mar 2015 at 10:57pm |
I bought a 712s this winter too. Mine didn't come with a snowblower and don't really want one. Where in IL. did ya get it?
Ya cain't fix stupid.
A-Cvtx
Posted: 20 Mar 2015 at 9:16am |
Cooksville, Dgrader. Thanks Steve in NJ! I really don't need snow blower here in NC. Gonna see if it works well, maybe sell it next winter. Yes! 26X12X12's!! Also, stock wheels and tires.
A-Cvtx
Posted: 20 Mar 2015 at 9:20am |
Unless I can use the blower for leaves!! LOL!!
Ethan Souerdike
Posted: 20 Mar 2015 at 10:48am |
nice find
If the women don't find you handsome, they should at least find you handy.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 20 Mar 2015 at 11:37am |
Cut the auger off and add a set of flails on the shaft. Then enclose all but maybe a 3 inch gap at the bottom front of it and I'd bet it will chop and blow leaves, You could even add a longer chute to blow them in a trailer wagon. ![]() |
Dgrader
Posted: 20 Mar 2015 at 9:00pm |
Tuck, I've got 3 big gum ball trees in my yard. Ya reckon your adaptation would work for gum balls?
CTuckerNWIL
Posted: 21 Mar 2015 at 12:47pm |
I don't know for gumballs. Maybe you need a dispenser.
A-Cvtx
Posted: 21 Mar 2015 at 5:05pm |
HAHAHAHAHAHAAAAAA!!!!!
Dgrader
Posted: 21 Mar 2015 at 6:02pm |
Maybe I do need a dispenser.
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 21 Mar 2015 at 8:45pm |
Charlie Tucker : You have too much time on yur hands! Better make one o' them impellers for a blower so u can refine it 'for u patent it!
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 22 Mar 2015 at 7:45am |
I have a snow thrower like that for my 917. It works great, never plugged it. I believe it would even move water.
Dusty
A-Cvtx
Posted: 28 Mar 2015 at 6:34pm |
Dusty MI
Posted: 28 Mar 2015 at 6:50pm |
On the tractor there are 2 pulleys, one of them, the one that puts spring tension, I think, there 2 holes on the strap iron that the pulley fastens to. You change the pulley to the other hole than the one used for the mower deck.
If that don't fix it I will have to check the belt routing. Dusty
A-Cvtx
Posted: 30 Mar 2015 at 4:19am |
I've watched a few Youtube videos and figured out the snowblower. From what I can see the tension pulley has been replaced with the wrong type of pulley. Now I gotta do some tests to see if the stator or the rectifier is the cause of my charging problems.
Mikez
Posted: 30 Mar 2015 at 9:13am |
Does that have a clutch on front of motor. Some of the 700s had clutch for snow blower on front of engine
A-Cvtx
Posted: 30 Mar 2015 at 6:00pm |
Yes Mikez, it does have an electric clutch. |
A-Cvtx
Posted: 30 Mar 2015 at 6:05pm |
Rectifier is good.
Mikez
Posted: 30 Mar 2015 at 11:10pm |
The one I'm thinking of isn't electric it would have a rod going up to a lever up on side of frame and look like the lever that controls mower deck.
A-Cvtx
Posted: 31 Mar 2015 at 3:51am |
Not too sure about the 700 series but I know the 300-400 series had both manual and electric pto. Depending on what you bought. I just converted my 312 to manual because the electric pto was discontinued, no one could give me a part number for one that "would work" as well. I found one in Texas that was re-man for $200. The parts to convert to manual was only $40 on eBay. No brainer.
Mikez
Posted: 31 Mar 2015 at 8:11am |
Oh ok yeah the 300-400s had ether. If your 712 don't have the front clutch then the blower was prolly rain off the center mower clutch. Good luck
A-Cvtx
Posted: 31 Mar 2015 at 8:08pm |
Mikez it does have the electric clutch on the front. The lever you see on the side controls the rear pto. I guess that's the one that runs tillers and stuff.
Edited by A-Cvtx - 31 Mar 2015 at 8:09pm |
Mikez
Posted: 01 Apr 2015 at 9:11pm |
O wow never seen electric on 700s. Learn something new. That lever yes will do your rear stuff as well as mower deck.
The 900s they run the blower off that same clutch that the lever goes to |
A-Cvtx
Posted: 03 Apr 2015 at 4:52pm |
It may be an add on by a previous owner but it is electric.
