426 camshaft
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Topic: 426 camshaft
    Posted: 19 Mar 2015 at 8:40am
    Just had my 426 camshaft reground for higher lift and longer duration by Colt cams. This was his first performance Allis cam. For all you pullers out there the exhaust side is very inefficient, bad lift and duration. He said intake was little better. By improving the exh it will spool up turbo much better.
   Since Colt put lot of development in cam he's looking for more business.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 9:05am
How much was the regrind?
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
AC 7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 10:48am
I also might be interested in a cam how much and what rpm range is it designed for
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 4:16pm
  375.00 for regrind, 108.00 for resurfacing 12 tappets. The cam is for 3000-4000 rpms. If you go to Colt cams web sight there is little more info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 10:30am
I would suppose you have to cut the pistons for valve clearance? Correct?or?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 8:10am
   Not sure about clearance, didnt go with huge lift to keep lugging ability, but Im going to check with playdo any way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 8:17am
Yeah I'd be really interested in seeing if it clears. I wonder if he could go alittle milder on profile for a farm/pulling tractor. Hmmmm...
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 8:34am
  You could call him, very nice informative guy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 7:16am
Any update on this? Just curious.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 8:03am
It is more than just lift that affects the piston to valve clearance. Durations and event timing have to be considered. If the reground cam has more duration and more lift than a stock cam I would guess you will need to machine the pistons for clearance. There wasn't much room with a factory cam in it.
Edited by O.P.S. Heads - 21 May 2015 at 8:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 8:44am
  Stupid farming, planting done, still picking rocks, in process of removing front of engine, will let you know.  Soon???????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2015 at 8:13am
I always wondered how you get a 301 diesel to run good at 3000 rpm limits , I kno they run real good at 4500 rpm,s ; someone told me get the cam reground- cheap power
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 4:45pm
   Still not done picking rocks, but I did check those clearances. Intake at 090, Ex at 045, I noticed when I set the lash sure had tighten up the Ex lots more.
  Ive read for 6000 rpm motor clearance should be 080, would 060 work for 4000 rpm motor, thoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 4:47pm
   Yes duration was increased, especially Ex.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2015 at 8:24am
Any updates?
moblie120 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moblie120 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2015 at 2:19am
This was his first performance Allis cam. For all you pullers out there the exhaust side is very inefficient, bad lift and duration.meizu m2 note
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2015 at 8:25am
Originally posted by peterson peterson wrote:
Any updates?
  Whats the deal with machinists?, are they all slow?  Still waiting on my heads and block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 5:20pm
Anything yet?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 10:52pm
IT would be neat for a cam mfg / grinder to do baseline tests with the old stock cam designed in the 60s for a naturally aspirated engine as in the 3400 and 2800 engines to see what the difference if any would be with a modern grind in the field use engines. If the change is significant, what a business one might have...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 6:51am
I think there would be a nice gain in the torque of the engine, plus run cooler too!
Edited by peterson - 09 Jan 2016 at 7:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 4:17pm
Anything yet?
   Sigh, machinists latest is a death in his family, cant complain to him about that.
    Hope to have it running by spring????
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 1:31pm
A cam. grinding co. spec. is one thing, but the timing of the cam. in your engine,is another thing. The tolerances of the key ways in crank gears and cams gears, even the key slots  in the crank & cam has an effect on timing. In my experience I have found the timing to very as much as 7 degrees, even on stock engines. That will make a lot of difference in the way an engine performs. So check the timing to make sure it's to spec. or advance it to gain low rpm power, retard for high rpm power. But always check the valve to piston Clarence.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2016 at 5:43pm
You may be able to gain what you need by advancing the stock cam, about 8 degrees with offset key & installing stiffer valve springs, most importantly 1.75:1 rocker arms, as the stock rocker arms are 1.48:1 + stronger pushrods. But be sure to check the valve to piston clearance. The rocket arms & pushrods can be bought from Murphy's Machine in Hallsville Mo. 573 696 3655 or Kenney's Pulling parts 606 379 7490
CalSnider View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CalSnider Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 8:48am
is there anyone in the midwest that can grind a 426 cam shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2016 at 10:14am
No limit manufacturing in Marshfield wi
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 3:25pm
Hate to be the one always asking, but any update?
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 8:07pm
Peterson, how's your ride coming?  Lost track of your thread.
