Allis to Simplicity # convershion
dlewis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlewis Quote  Post ReplyReply Direct Link To This Post Topic: Allis to Simplicity # convershion
    Posted: 13 Mar 2015 at 10:17am
Need the breakdown on your Allis? Check this out. All #'s are simplicity #'s , but are the same tractor/ mower as your Allis. you go to simplicitypartstore.com and use this #s as your model #. You should find that the manuals/breakdowns are the same as your allis.  However some parts are no longer available and Part #'s don't cross over, in that case you have to put a 2 in front of the part # and then a SM behind it . So if u need part # 12345 and it does not come up, put in a 212345SM and try it that way . I hope this can help!!!!!
Allis B-10   is a 2025060
Allis 712S  is a 1690075
48'' deck    is a 1690021
42'' deck    is a 1690022
Tiller  is a 1690039
Sickle Bar  is a 1690030
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 3:08pm
http://www.simpletractors.com/Main/x-ref_table.htm
Big cross reference list.  You can go to the Simplicity web site and punch in the Simplicity model number and get a free PDF of the manual for the Simp version of an AC.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlewis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 8:16pm
yes a full break down,  try it you'll see. then print off for future references or what ever..
