b series stinger wt.
kieran holthaus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kieran holthaus Quote  Post ReplyReply Direct Link To This Post Topic: b series stinger wt.
    Posted: 08 Mar 2015 at 11:17am
does anyone have dimensions and a picture of rear stinger weight for b-10.110.112? thanks kieran
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 11:24am
Them little buggers are tough to find. I was gonna make one for my 716H a few years ago. My plan was to find an old spackle bucket, find a pipe that fits in the holder on the Tractor, set it in the middle of the bucket and poor concrete in the bucket around it. When dry, bust the bucket off, and you got one serious Stinger weight! I opted to put a diesel battery back there in a plastic case on a nice fabbed support bracket off the hitch and use the Diesel Battery to power the lift for the snow plow. Worked most excellent. Wasn't as heavy as the Concrete would have been, but with the aggressive ATV tires I had out back, the Battery was enough weight to keep the ATV tires biting. Also, that Diesel Battery took a lot off of the electrical system. I used to have a Battery tender hooked to the Battery between storms. Worked great for about 5 years. Gave the 716H to my nephew, and he's still using the same setup today!
Steve@B&B
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 11:36am
i used a front wheel wieght off a wd when useing the snowblower that would add traction also make lifting the blower almost effortless it was just hanging on a peice off round bar slipped in there never seen an oem one in real life
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 11:56am
Gary
http://www.simpletractors.com/attachments/options.htm
This page was generated in 0.097 seconds.
