1936 WC foot brake conversion
David Terry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Topic: 1936 WC foot brake conversion
    Posted: 08 Mar 2015 at 8:45am
I'm building a 1936 WC for pulling and I'm worried about being able to steer using the hand brakes. I've seen a conversion kit for a WC but I've not been able to locate one. Can foot brakes off of later models be adapted to the old flat fronts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 1:10pm
It only takes four hands to operate a WC........left brake.....right brake......steering wheel.....throttle lever (if the teeth won't hold the lever where you want it).
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 5:00pm
Not really.  You can home brew something, but you need a linkage from the foot pedal to the hand lever to operate it.  I'm thinking you steer with your knee, left brake, right brake. Back bevel the throttle notches with a file so it'll stay in the GO position.  Occasionally I'll see a kit come up for sale, just have to watch for them.
AaronSEIA
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 7:48pm
This is totally off the subject but it reminds me of the first time I was allowed to load cow manure out of a pile with my uncles WC. I was about 12 and the ground sloped (quite steep) away from the barn and manure pile, toward the spreader. Of course the loader was a hand trip and I could barely pull the trip with both hands. On my second load I ran into the side of the spreader, which ended my loading career for a while.
I forgot to add the brakes didn't grab very well and the tractor steered very hard, especially if you happened to get the bucket good and full.
A man could have used about 8 hands to load with that tractor!!!
Sorry for the rant!
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 10:09pm
i got a friction throttle control from a M farmall,its tension adjustable.next,move your seat to the middle of the tractor-i use my hand brakes about twice a season,you wont believe how better the balance is-good luck and have fun!
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2015 at 8:48pm
I think that hand brakes on the WC is an advantage. When I'm pulling the hand brakes just seem to be more instinctive than any tractor that I've pulled with footbrakes...by the time that the front end starts floating I'm usually at full throttle so my hands have nothing else to do!
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2015 at 9:29am
I think what I'll do is add a extension on the left hand side so I can reach it from the seat easily and then give it a try in this springs pulls. May not be the problem I anticipate. Thanks, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2015 at 1:52pm
When I was a young kid, my first tractor driving jobs were on my uncle's WC and my grandfather's WF (which I now own). Of course both had hand brakes. It took me a while to get used to foot brakes on the "big tractors" (WD & WD-45).
One place I do not like hand brakes is loading a tractor on a trailer or truck.
I bet you adapt in a hurry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2015 at 3:59pm
Put an ad in the classifieds.  AC made an extension for the hand brake levers when using a cultivator.  You could home brew one too if you so desire.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2015 at 4:39pm
I refer to those lever extensions as the "Power Brake" option.
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 9:36am
we took a brake setup off a wd made a bracket to hold brake shaft and links with swivels on ends and it works decent
ACJake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACJake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 9:02pm
at our local pulls you must have a hand on the steering wheel at all times, SO....... when pulling my 36 WC i hook my left arm through the steering wheel spokes and use it to control the right brake and made a special bent adaptor to control the left brake with my right arm. sounds complicated but it works for me. I pull in the 3 1/2 mph class so Im not going boogity boogity down the track
3 WC's, 2 WD's, 3 WD-5's, D-14 w/HenryBackhoe, D-17, 4 D-19's, 185, 190XTsIII, 200, 210, 7010, 10 L&G Allis's. Nunn Better Farms Bleed Orange!!!!!
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 9:08pm
Anyone ever used WD brake pedels on a WC?
~AMP~
This page was generated in 0.065 seconds.
