220 |
Toscani NE SD
Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
Topic: 220Posted: 07 Mar 2015 at 8:06pm |
buddy of mine has a 220 that needs injectors rebuilt,i told him I heard on this site to use 7080 tips, can he do this and not modify the pump?will it provide any hp gains using stock pump?and if so approx. how much more,also his turbo is shot,is there any turbo stock from any other allis that would bolt on and go with no mods? I told him since he has to do all this u may as well try to gain some hp,thankyou!
DrAllis
Posted: 08 Mar 2015 at 8:45am |
7080 tips set to 220 pop-off pressures will up the HP a bit, but not more than 10 HP. Any turbo from a 7030-40-50-60 will bolt right on after being "clocked" correctly as long as it is an Air-Research brand.
