720 620 616 trans oil |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Topic: 720 620 616 trans oilPosted: 04 Mar 2015 at 1:01pm |
anyone use power trans. hyd. oil in these tractors
aras
Joined: 28 Jul 2011 Location: Weston, WI Points: 665 |
Posted: 04 Mar 2015 at 1:07pm |
I'm rather sure they use ATF
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2092 |
Posted: 04 Mar 2015 at 2:52pm |
I use ATF with good luck. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Posted: 04 Mar 2015 at 11:20pm |
dexron 3
HudCo
Posted: 05 Mar 2015 at 9:07am |
one of our customers use hy tran in his 720 in his trans and loader but i ask becausse we just when through a massey 40 and i put hyd. in the gear pump for the steering an d you could not turn with both hands put atf in and you could turn end of finger the sundstrand pump on the 616 looks like it could go right on ih combine by the way the customer with the massey had been using brake fluid in the power steering wich mostly was going inthe crankcase so you can guess what the crank looked like
