model 220 voltage regulator location?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Topic: model 220 voltage regulator location?
    Posted: 29 Mar 2010 at 3:23pm
I am slowly getting the 220 back the way it should be and the latest bag of parts includes a new alternator equipped for the tach drive. Like the original it has a separate regulator. The one on the tractor now is internally regulated so they pitched the regulator,  where was the regulator mounted originally?
190XTLP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTLP Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 3:27pm
it was located behind the insturment panel,remove the cove on top
of the hood ,8 bolts
WD45G,WD45D.190XTD,190XTLP
D19LP,WC unstyled,WF unstyled
WC styled,220
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 10:13pm
Should be where 190XTLP said, it should be a plug type with a ground wire.
Edited by Adam Stratton - 29 Mar 2010 at 10:13pm
This page was generated in 0.131 seconds.
