D-10 side hooks for hood latches
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: D-10 side hooks for hood latches
    Posted: 29 Mar 2010 at 1:11pm
Anyone know where I could get a pair of these or have a specs that could be used to fabricate them? These are the hooks that are on the Radiator shroud to hook the front latches of the hood. Any help would be appreciated! :) Thanks
Austin
"Better By Design"
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 1:48pm
Look up latches at www.mcmaster.com
Gerald J.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 2:20pm
Seems like Norm at Norm's Toys has these.  Also may have seen them in ads in the Old Allis News.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 3:05pm
"Better By Design"
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 10:19pm
I took a pair to a show and had the blacksmith make me a set. How they turn out is dependent on his skill - but they work . Was the bottom of the latch - not the top.
I used to be young and stupid, now I am not young anymore.
MBwcenll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcenll Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 10:40pm
Are you talking about the part that goes on the radiator shell?  I had to make my own from  flat steel.  I used a cut off wheel and a metal blade in a jig saw.  I was lucky I used my brother's D12 as a pattern.  There is a left and right.  Both are cut out the same, just bend the hook opposite to make a pair.  They are shaped different than the example "H" that is circled in above posting.  Same idea but not the same shape.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 9:23pm
I sell new roller mills that have exactly the same latch on some guards as the D series tractor hoods. I can also buy them at my local industrial fastner supplier.
