HD15 BODY SHOP
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Topic: HD15 BODY SHOP
    Posted: 28 Feb 2015 at 11:48am
Ok, I got behind on posting. But this is some of the body work that AC tractors might need, but I can't find this in the service manual or service bulletins, so we just make it up as we go.  photo P2130031_zpsqsrqhycx.jpg
Some of these things don't look as nice once there painted with all these cracks in them. My body work style consists of filling the cracks with .035 wire and a compliment of 2 different size grinders and a couple of die grinders with sanding disks. photo P2130030_zpsiw26yflu.jpg
These all needed some attention. We usually wander around the yard looking for the best ones to start with. (we have several donor tractors) I'm a weld and grind kinda guy, but if they need final touch up with bondo and putty my brother specializes in that (I don't do wood either) photo P2140036_zpsqah2fm9j.jpg
Front radiator guard could have used new screen, but I think you won't be able to tell when I'm done (I'll try to post pictures so you can't tell  photo P2140037_zpsf8cciwrr.jpg
The A frame for the cable blade needed some welding and the 3 bolts in the control lever bearing holder all broke and had to be drilled and tapped again photo P2150040_zpstizflohv.jpg
We found a better tank guard (donor tractor) that only needed welding and grinding instead of major straightening.  photo P2150043_zps4qxsfqhr.jpg
One of the other things we've learned is that trying to paint plated bolts is a pain. Most all suppliers seem to only stock plated bolts anymore photo P2260017_zpswj75k3qk.jpg
Our supplier would get us plain black nuts and bolts, but I didn't get started on that in time. So are driver John dug through bolts and found some of the appropriate AC sizes, washed them with super clean, dried them and prepared them for paint   photo P2260018_zps2jexzhh8.jpg
Of course this is done with Hooch's supervision cause he knows some one can at least kick the tennis ball while there working photo P2260020_zpsq1kjfch5.jpg
So when David starts painting they look like this photo P2260028_zpshwyguhxb.jpg
John also masked the guages for painting after we replaced all of them to the original AC 3 screw flange type guages. (one was even brass). We have just about used up all of the original guages from our donor tractors, so be on the lookout for those for us please. photo P2260025_zpsucx1apet.jpg
So the story gets better. I brought the canopy over for some simple body work.  photo P2270041_zpsicz16orz.jpg
Thought I could straighten one side and replace one side photo P2270043_zpscrbdvkmy.jpg
So I thought a straightening would be simple enough with all are metal technology.(LOL) So I brought are 2 John Deere backhoes to the scene for a quick fix. photo P2270044_zps9gulpcog.jpg UH-UH (it was beer time, so 2 beers later) I did what any knowledgeable mechanic would do. GOT A BIGGER HAMMER!. The 745 didn't have any problem holding it down and the backhoe bucket has more strength than the front bucket.  photo P2270046_zpsuagslpjw.jpg
As I said I can't find any of this in the service manuals, so make notes for your future restoration projects. The paint shops also open, so I'll try to get that post up soon.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 7:36pm
Excellent work Mel. A few beers often sheds new light on engineering challenges. A few too many can create engineering challenges!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 8:54pm
Thanks for the up-date, Mel. Thought my 645 was a beast, but I think that 745 could eat it for lunch. Darrel
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 5:44am
Dang wish i had a playground like that A guy could have fun for quite some time !!!
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 12:36pm
Great step by step restoration, lucky to have the donor tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 12:55pm
Mel,
 I don't think those are standard body shop tools:) Big iron needs bigger iron to get the dents out!
Your repair techniques sound a lot like mine (on a smaller scale). A welder, a torch and a two pound hammer are some times the tools of choice.
Great shots! Our Maggie (Golden retriever) brings a ball to me all the time when I am working on tractors.
I cleaned bolts and hardware this morning for the WD project. Trying to get some of this done ahead so when we get some warm weather I can do some assembly work.
This is going to be a good looking machine when your done!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 2:12pm
Mel, Your posts makes me want to bring my HD-15 out to you to do a little overhaul and repaint...
 Left track nearly falls off, don't have the proper aircleaners, seals are gone in the blower (nose up, nose down, hang on and she is gone and you turn black from oil blowing out the stack) and big tank needs cleaning and a lot of TLC of 40 years of neglect... Got hardnose and hydraulic blade on her.
... Unlike your your shop, mine is a bit cooler, can frees your beer on one side of the can and heat up the other...in minutes...  unless you stick it in the shade... then it'll be frizzed thru an thru.  High of 20 degrees right now...an that ain't celsius either, that would be -7.
  Mel, You got a few minutes to fit her in your shop schedual?
 On second thought, I'm afraid it might end up in the doner pile by mistake...Or by intention. LOL
This page was generated in 0.285 seconds.
