The best mower deck spindle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: The best mower deck spindle?
    Posted: 27 Feb 2015 at 2:28pm
Who has the best mower deck spindle? In ease of maintenance ,replacement and longevity for the cost? Thanks Tracy
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2015 at 3:45pm
I like the spindles on our Scag and Bunton mowers. The spindles are hollow and use a long 5/8 bolt and nut to retain the blades instead of cap screws and common flat washers can be used if you lose the spacers some how. Bearings are common off the shelf too but in 10 years we have not had to change any.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2015 at 5:23pm
Butch, the spindle assy for the 616-620 are about 400.00 each, less pulleys and bearings. I think I am going to make a new style like the Dixie Chopper uses.They look heavy and should last like the ones you mentioned. Thanks tracy
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 8:27am
in my opinion u should never need a new spindle,my 620 which I bought used still has all original spindles everything is original no new bearings,if you grease them often u wont have any trouble,mine has mowed a lot of acres,i also have several large john deeres with 60" decks,never replaced a bearing yet,over 1300 hrs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 3:53pm
That would be great, but mine had been abused before I got it. You sure don't want to buy any new ones, at the price they are now.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 4:45pm
thats areal good question used ones i would probley rebiuld cast iron john deere huosings  new ones just looking in the oregon catalog at new ones probley would order some for bobcat or exmark  we sell a ton of the newer mtd and ayp spindles they are cheap but not very toughf
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 5:27pm
One trick I picked up is to add a grease zerk( if not already there) and pop the 'dust shields' of the bearings to expose the race to the grease. Neighbour has  25 years service doing that. He also removes the spindle assemblies every fall, greases the nuts/bolts holding them onto the deck. 'Old school' stuff....
sure wish I could get $400 for a spindle !!
heck I'd settle for $200....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 5:50pm
Swisher mower I have the deck bearings went out , found they used sealed bearings but not shielded =  so I replaced with sealed and shielded bearings - was thinking of adding grease zerk to space and pulling the inside seals but figured 4 years service on first set - so should last about the same or longer this time around .
This page was generated in 0.438 seconds.
