Belt Questions 912
Hubcap View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubcap Quote  Post ReplyReply Direct Link To This Post Topic: Belt Questions 912
    Posted: 24 Feb 2015 at 8:23pm
What would usually cause the belts to come off the pulleys ? In particular when shifting from hi to low ? I replaced the low gear belt today. The high gear belt I did not replace because it looks ok. Will one new belt cause another used belt to come off a pulley ?
Looks like there is some kind of rod with a spring on the end some kind of tensioner and there is a gap play at end of spring and both nuts are tightened as far as they can go down the threads.
Any feedback will be appreciated. Thanks
This page was generated in 0.170 seconds.
