D19
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Topic: D19
    Posted: 28 Mar 2010 at 5:54pm
I have been looking for a good cylinder head for my D19 diesel without luck for a long time. Now my question is there are a couple different casting numbers and my old one was 4514790 and they say its unrepairable and I was just wondering if any of the other casting numbers will work right on my tractor. It would be really great if I could get some help on this, Thanks.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 6:58pm
As far as I know there was two D-19D heads. Early one had a place to attach the water pump, later heads did not as the pump was moved to the block. When I was looking for a WD-45D head I used a place called THE Company out of Iowa http://www.the-co.com/ They had the best prices at the time and are great to deal with. I punched that casting number into Google and it is listed several places as available but who knows if they actualy have one unless you call,
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 8:23pm
To my knowledge, the D-19 never had the water pump inlet in the head as the WD-45D's and early D-17's. A D-17 Series III or series IV diesel head is the same design and may work.
I did not check the part numbers.
