hd6g clutch
Mosasquatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mosasquatch Quote  Post ReplyReply Direct Link To This Post Topic: hd6g clutch
    Posted: 16 Feb 2015 at 8:13pm
anyone know any tricks to reinstalling clutch housing back in?took 4 hrs to get out no room to get it thru the frame. goin on 6hrs tring get back Can the tranny nose be removed? what kind and how big of a can of worms would that create?
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 1:05am
You can take the yoke off the trans input shaft, but nothing else would have to move
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 7:49am
Get comfortable laying on your side with your head down. I like to take the steering clutch levers off. I use a pilot shaft to align the disk and support the pressure plate. I use 2 phillips screw drivers to help with the pressure plate. Last time I did one I wished for some method of supporting myself comfortably like a sling from an overhead crane. I use pillows protected by dog food bags to lay on and support my head while I'm hanging upside down working on the clutch. If you have trouble removing the bellhousing you may have to loosen the rear motor mount and raise the rear of the motor slightly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mosasquatch Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 8:58am
we have clutch flywheel and everything else under control just cant get theclutch housing thru the frame We removed all levers including steering levers end brake pedals also yoke on transmission still no luck. transmission shifter nose cone is in the way can this be removed
how much trouble is that we dont know whats inside shifter nose cone on tranny dont to open a can of worms
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 10:01am
You are telling me that you got the bellhousing out but can not get it back in place. It is a real pain but it does fit without removing the transmission nose. Are you trying to put the bellhousing in place with the clutch shaft attached to the bellhousing? Good luck
creeperfreak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote creeperfreak Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 11:24am
If an HD6 is like a 5 the bell housing (sans clutch shaft) is set in place with the clutch resting inside it.  That gives an inch or so of space to bolt up the clutch and then the bell housing is moved forward to be bolted in.
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 9:03pm
I did the clutch in my HD6G 25013 I ended up taking the motor out, that wasn't an issue as we had an excavator handy, and with the nosecone tilted and the radiator out there's not much else other than the pump to remove, once out I did the engine bearings as every thing was exposed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2015 at 7:28am
Welcome Donoman I am sending you a Private Message about main bearings for your HD6 motor. I wonder how many other members are from New Zealand?
When I could not find main bearings for my HD6G I found an AC dealer in Puerto Rico and purchased his remaining stock. I also have an HD344 crankshaft that I had rebuilt 0.010/0.010 because it spun #4 rod bearing that is for sale.
This page was generated in 0.243 seconds.
