B110 mower deck issue
Emory View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Emory Quote  Post ReplyReply Direct Link To This Post Topic: B110 mower deck issue
    Posted: 16 Feb 2015 at 5:13pm
Good evening,
I'm starting to think spring. My issue with my Allis is that when driving over drainage swails the mower deck pto belt blows off. It happens when the you are just cresting the swail with the rear of the deck. It seems like it comes up to far causing the angle to be to far out of phase allowing the belt to run off. Anyone out there run into this issue? I used the tractor as a kid but it sat idle for many years until I inherited her from my late grandfather so i have no one to ask questions to. Thanks!
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 5:34pm
Iv found that u got to use ac or simplicity belts only and make shure ur belt tension and adjustment is right
Post Options Post Options   Thanks (0) Thanks(0)   Quote Emory Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 6:10pm
Hmm, running simplicity belts, tension is good. The deck will actually come up and push the belt upwards and off the deck pulley. Is there supposed to be a "stop" of sorts to limit upwards travel on the rear of the deck?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 8:49pm
sounds to me one of the belt giudes is missing problley taken off to change a belt or do maintance and wasn t put back on
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 12:23am
I have the same problem with my B110. You can NOT run the deck in the raised position or it WILL jump the belt off every time. I usually do not have an issue with ground contours raising the deck up enough to jump the belt though. Mine is missing at least 1 belt guide that I know of. Even with the guides though you don't want to raise the deck while running. I've noticed that the deck will hit the mule drive at full raise.
This page was generated in 0.285 seconds.
