WD-45D PTO Gear Tooth
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Topic: WD-45D PTO Gear Tooth
    Posted: 28 Mar 2010 at 3:26pm
Anyone happen to know and can verify the number of teeth on lower gear in PTO drive? Was told 28, I have one with 29. Also is the Housing different than a Gas PTO Housing? Diesel has casting #AM-4200 on it. Thanks
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 6:25pm
The diesel has 29 teeth, the gas has 25.  The housing is different too, there are only a couple pieces that are the same.  Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 7:24pm
Thank-You, Tom, Chris/CT
