M 100 B Grader
kodiak2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kodiak2 Quote  Post ReplyReply Direct Link To This Post Topic: M 100 B Grader
    Posted: 15 Feb 2015 at 9:47pm
HI,
I bought a AC M 100 B grader with a wing. Have no serial # as they removed it when they installed the wing. The wing is off and when I went to use it, it would run for about 2 minutes and then quit although starting right up again and repeating the problem.Had the injectors and pump rebuilt, but haven't got it altogether yet. Needs a lot of work including blade hydraulic cylinder rebuilding. Anyone have any advice on rebuilding the engine and other parts? I'm a retired crane operator and have run Cat 16G graders but don't claim to be a grader hand as most of my work has been in snow removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 5:29pm
bump
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2015 at 9:01pm
The running for 2 minutes stalling but restarting sounds a lot like restriction in the fuel supply...filters...debris in the bottom of the fuel tank or fuel lines...?
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2015 at 5:41am
The M-100B use a motor 10000
