D grader
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: D grader
    Posted: 15 Feb 2015 at 7:33pm
where can I find the serial number listing for the model D graders. The town here is going to sell theirs, would like to know what year it is, does have the WD45 engine in it.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 7:43pm
Norms book or post it here, I or someone else could tell you the year.
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 7:59pm
The tag should be on the frame on the right side where you climb into cab. It'll start with D. Ours is D427, which makes it a 1949.
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 8:16pm
[IMG]uploads/10101/MVC-026S.JPG[/IMG The aluminum tag will be riveted to the R.H. side of the frame where you step into the operators platform.   Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 8:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 8:28pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 10:40pm
Post your ser# and I can tell you the year and what engine you have in it. The D graders used the WD/WD45/ D17 engines.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 11:30pm
D3824 would be 1954 and it would have the G226 engine that was used in the WD45 farm tractor. From the picture it almost looks as if it has a square frame. The square frame didn't start until 1964. If it is a diesel engine and it is a DD grader then s/n 3842 would make it a 1967 model. The serial number shown does start with a D so I am confused. Perhaps the old round tube frame failed and they rebuilt it with a square frame. More pictures please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 9:29am
   Hi Don.   You are correct with these serial numbers.
    The first picture is of a round frame on a 1954 open station D grader that had just completed building a golf course in Orangeville, Ontario. The second picture is of my grader. This square framed, 1967 'D Special' is now an open stationed unit.
    I am sorry for the confusion. I was trying to explain where the units serial numbers are located.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 1:32pm
Sorry Ross. Late at night and I didn't look at who was posting the pictures. I guess I just assumed that it was the original poster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2015 at 9:58am
Good morning.   Is there an update on this inquiry?    Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2015 at 6:05pm
If you can't find the tag on the grader. You might look on top of the hydraulic control box. That's where I found ours.
This page was generated in 0.158 seconds.
