Tractor Upgrade?
Sam (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam (WI) Quote  Post ReplyReply Direct Link To This Post Topic: Tractor Upgrade?
    Posted: 14 Feb 2015 at 11:18pm
I am in need of a better tractor for general use and for working around 6 acres of ground. I am currently using an Allis C for plowing and as a loader tractor and a Cub lo-boy for mowing and moving wagons. The Hederson loader I have for the C isn't all that great and I am worried that without much of a sub-frame that I could break a casting.  I have been looking to either upgrade the C to a CA or sell my C and buy a CA or WD45 sized tractor.
 My ideas are:
1. Find the back half of a CA and use my front half to build a C-CA mutt.
2. Sell my C and buy a CA outright
3. Sell my C and buy a different row crop tractor
I plan to use whatever tractor to plow, disc, plant, gather fire wood, move snow, and for light loader work. I know that other people have been in similar position and I am looking for any thoughts and ideas.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 4:25am
I would get a WD45, if your looking for frame strength, a CA isn't going to be any stronger then a C. if your going to use it for a loader tractor.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 6:45am
WD45 would be a good one for you I think, nothing wrong with a WD either for your use.  They are easy to mount a loader on and with tire chains can move lots of snow.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 7:21am
A WD45 with a 4 bolt WFE and power steering would be slick for what you want to do!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 7:40am
I love my 9523 Simplicity/5020 Allis Chalmers with a loader. It gives you a true three point. (same tractor sold by two companies)
It has 11-2 x 24's on the rear now. I had plans of making it look like an Oliver 550 at one time.
What it looks like today.
Edited by Dick L - 15 Feb 2015 at 11:03am
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 9:30am
I have 5 acres.  My 5020 is okay but a little small.  My D14 is perfect, I did put a 3 point conversion on it.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 9:51am
I used a plain straight WD with a Paulson loader for many years and never experienced any problems. Might want to add that to your list of options as around here the WD is spurned a bit over the 45 and you could probably save $1K if that is a factor for you. My 2 cents.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 10:35am
I agree with you EPALLIS. The WD's don't get as much respect as the 45's, yet they are just as durable if not more so. They are cheaper to buy which is another plus.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 10:47am
If you're looking for a cheap, modern-ish, bullet-proof tractor, I don't think you can beat a WD. 30HP on the drawbar, factory hydraulics and lift system, live power with the hand clutch. Over 140,000 built, so there are TONs of used parts. Easy to work on if you need to. The best part is that most of them that need a little love can be bought for less than a grand. You just have to get used to the gear whine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 11:05am
Bigger tractors are always better. That is why I bought Oliver 1850's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 1:54pm
I'd agree with everyone who is trying to steer you to a WD. Clap It all depends what is available in your area.  That or a WD45. Daunting at first, but then pretty easy to work on.
NOW, I wouldn't sell that C unless money is an issue.  You'll wish you had it back shortly after you sell it.  Find a mower for it and sell the Cub.
Me, I have a HARD TIME getting rid of any once they are in the farm yard.. LOL LOL
Hillmann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hillmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 7:18pm
If you do get a wd and plan to use it for any loader work get one with power steering.  Wide front would be nice too but.
My WD will lift over a ton before the rear wheels come off the ground but once I get more than a few hundred lbs in the loader steering becomes difficult and once I have more than 1500 pounds I can't steer at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 10:44pm
Is their anything wrong with the CA as a loader tractor? I don't plan on really moving anything other than snow and gravel for the drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 6:40pm
I have about 4 acres and we have two WD's and a Ford Jubilee, Always find something for them to do.:) Dont have a loader but that would be nice. Plus a bunch of Cub Cadets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 7:23pm
Not one thing wrong with a loader on a CA or a C or a B. I have a Henderson loader out back I removed from a CA that I want to put on a B. (some day)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 9:59pm
I have a Henderson loader on my B. I use it more for lifting engines, finals, and whatever more than using it on the property. Although it does work great pushin' back the compost pile every once in a while...... Its my rubber tire engine crane.  LOL!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 10:46pm
The problems that have come up while using the c are a lack of traction and the lack of a rear lift system. It has trouble pulling loaded wagons on packed snow. I have thought about loading the rear tires with fluid to help with this. The lack of any type of rear system has been preventing me from getting a rear blade which would be very helpful in pulling snow away from buildings. I have been looking for a CA parts tractor to take all the snap coupler parts off but none have come up. Thanks for all the good advice!
8050/8030/185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8050/8030/185 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 3:36am
Owned a WD and never got along too well with it. Used a CA and was real unhappy with it. Got into the D series and loved them to death. Look real hard at D14, D15, and D17. The D17 gives you a lot more choices in tools and power.  I use a JD compact tractor for my 6 acres of garden and mowing, mainly have it for the FWA and hydrostat. D15 diesels are almost impossible to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 10:39am
Does everyone with a loader on a small tractor have fluid in the tires?
Should I be able to drive through say 6 in of snow with out getting stuck?
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 10:47am
we have fluid in the back tires of a WD-45 with a loader and Case VAC with a loader. helps tremendously
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 4:48pm
Looks like most of mine have the crap in the rear tires,---some of them I did manage to get drained out before it eats up the rims any further!
I own/use ac 440's---190 xtd III--B--C-- WD--WD-45 and 917 (18 hp upgrade engine) the 917 has plow for the smaller plots and one of the 45's plows the bigger plots!
For 6 acres I would look into the D series if more modern is what you want! as far as cub goes --it needs a new address! LOL!---I got 8 of them here taking up valuable space and only 1 is usable because I made a 3-pt hitch for it and cub sized equipment to use on it! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 7:05pm
Yes, you need weight. Quick cheap weight for the C would be to place a plank over the drawbar and stack sand bags or such. Any time you put more weight on one end of a teeter totter than the other the light end comes up. If you have a loader out beyond the front of your tractor you have created a teeter totter out of your tractor and loader. Note my counter weight on my loader tractor. If I have room to operate I sometimes use the disc as a counter weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 7:08pm
  My 45 has rears full. It would be worthless with a loader without fluid. The fluid won't rot your rims unless it leaks out somewhere and gets on them. I had to replace a rim on mine   ( dang thing only lasted 40 years) since the PO didn't change out the valve stems regularly and the right one started leaking.
 I'm thinking of using windshield washer fluid or used anti freeze Shocked in the CA when I get it going again.
Edited by CTuckerNWIL - 18 Feb 2015 at 7:10pm
T.J.-N.J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T.J.-N.J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 7:50pm
I like my C a lot I probably use it more than my other tractors the aftermarket three point hitch (worksaver) is a basic hitch nothing fancy, Once the plowing and discing is done the bush hog rarely comes off.Incedently my loader tractor is a 52 Farm all Cub.You can get an old 4x4 pickup for moving wagons. My uncle used my B until he retired from farming before he got a bigger tractor he only contracted out the combining. He was a Tennant farmer and worked about 85 acres doing hay and feed for the cows,he would think I'm nuts he had one tractor for 85 acres I have 8 tractors for 5 acres but the B & C were the only tractor on a lot of farms for a lot of years.T.J.
This page was generated in 0.350 seconds.
