840 wheel loader
little red dogs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote little red dogs Quote  Post ReplyReply Direct Link To This Post Topic: 840 wheel loader
    Posted: 12 Feb 2015 at 7:55am
looking for  some advice on tran. in 840 wheel loader. it takes on hour sometimes 2 hours to get warm enough to move. after it warms up its works great .changes fluids,filters,cleaned out the broken parts from the broken filter housing.                                                         thanks terry
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 4:05pm
Do you know if your transmission has the tubular metal screen in the bottom of the steel housing? Usually accessed by a plug facing the back and or the front at the bottom of the steel case housing. If this screen is plugged it won't pick up pressure for the clutches. There can be lots of debris at the bottom that needs flushing out in addition to cleaning the screen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote little red dogs Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 6:01pm
thank you Eric i will try that ,i will let you know if it works
This page was generated in 0.344 seconds.
