190 pressure plate springs
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: 190 pressure plate springs
    Posted: 11 Feb 2015 at 11:24am
Hi all I have a 190 diesel that I pull and the clutch is the factory one that came on the 2500 gas engin and I need put heaver springs in it or replace it for this pulling season. I would gess and say it's making about 280hp what kind of springs do I need or what clutch should I use.ps runs almost 3000 rpm and I can't go higher for the class.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2015 at 1:07pm
Buy a new pressure plate from Hy Capacity or whomever with the highest pressure springs you can get. Or add those springs (if they can be purchased separately) to your existing psi plate. Add feeder beater spring cut to the correct length inside of the pressure plate springs. Dr. Allis can tell you just how to do that. He's done a few. Be sure to use a 4 pad clutch disk. Be sure the flywheel is machined to the correct dimension from the friction surface to the pressure plate mounting / face area. Make sure your rear engine seal and clutch shaft seal are not leaking. If they are, replace them.
If your power director is still in it, it should have the hydraulic pressure increased if you haven't done that already. If you do all of those things to the flywheel clutch and something is still slipping it is most likely the power director. There is a fix to that also.
Edited by O.P.S. Heads - 11 Feb 2015 at 1:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2015 at 9:55pm
Use a full disc, centerised iron plate.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 7:28am
Mack I don't understand what u r referring to. I'm kinda new to the bilding a puller. A little more information would be great.I don't won't to sound dumb .
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 8:05am
He's referring to a disc that really doesn't have any pads, just solid all the way around. Here's one place to get it from.
http://kennyspullingparts.com/replacement-clutch-parts.html
Call them up and tell them you need a 12" disc with 1 1/4" 10 spline hub.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 3:52pm
I called Kenny and he said he could do one for me and for a good price. But I was wondering if I could use his pressure plate and a factor drive disk for a 200 .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 6:44pm
Just get a pressure plate for 190-200 and have the lavender or purple springs put in it. Should work pretty dang good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 7:28pm
Ware would I get those springs from? Iv tryed finding heaver springs and no luck I'm limited around hear for this stuff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 7:30pm
Local Agco dealer should be able to get them from where they get there clutches rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 7:34pm
My local dealer could get it for ya and ship it to you. Just get a reman pressure plate with them already installed. Niemuth implement 715-678-2271 talk to Ronny. Tell him Tyler Peterson sent ya.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 9:48pm
Call Darren Rursch at Taylor Ridge, Il 309 795 1502. Darren was in the tractor pulling clutch business when Kenny was still wearing his diper. Darren will do you right.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 2:45am
Rick on this forum can get u set up with them too , they do excellent work on clutches and pressure plates
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 6:00am
I have tryed both the agco dealers ware I live and they can't help me. Thanks for the info and numbers I will be making calls. thanks everyone.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2015 at 6:10am
Ronnie...PM me.  Rick
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 8:16pm
Question:
I am debating on installing the Feeder springs,,,, however my pressure plate has YELLOW springs in it and this clutch pedal is noticeably harder to push down than my other 190xt. This tractor has not pulled and will be equipped with 450 roosa, .093 lines and 4 x .020 injects, 4 pad clutch.
AC manual states :
Lavender springs free length of 2-9/16  and test 185-190 lbs when compress to height of 1-13/16  when new
Black (painted) springs free lenght  of 2-9/16 and test 155-165 lbs when compressed to a height of 1-13/16 when new
Yellow springs ?
Edited by Beirnesy - 13 Mar 2016 at 12:31pm
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 8:00pm
The springs you are talking about are die press springs.
 There are places in bigger cities that have all sizes of this type spring. Google die press springs and i'm sure there will be all sizes.
 Years ago when I was running spring clutches, I bought some from  spring Co. in K.C.
 If you use them, check crank thrust from time to time.     MACK
This page was generated in 0.083 seconds.
