best carb
big d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote big d Quote  Post ReplyReply Direct Link To This Post Topic: best carb
    Posted: 09 Feb 2015 at 8:54pm
I have a wd45 with a 226 what is the best down draft carb for pulling
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2015 at 8:02am
don't know where your from but most places make you use updraft carb
Post Options Post Options   Thanks (0) Thanks(0)   Quote big d Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2015 at 6:00pm
I live in tn and the pulls around here at least the ones I pull in allow it
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2015 at 6:02am
Did you design a whole new manifold?
Charlie
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2015 at 6:04pm
wonder if he really means up draft
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2015 at 6:40pm
Just another wannabe puller who thinks something as simple as a different carb will double the HP of his engine??
Post Options Post Options   Thanks (0) Thanks(0)   Quote big d Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2015 at 9:25pm
No I'm not just another wannabe puller I have ported the head I have 4/18 overbore m&w pistons a custom header 3 angle valve job and the crank has been offset with wd45 diesel rods and a reground can changed over to electronic ignition with a 50,000 volt coil no I didn't mean updraft carb it has a zenith on it now that has a bigger jet so I know a little bit about pulling
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 5:42am
Well then, you'll have to ask one of your competitors what they recommend as the "best" down-draft carb for your specific application. Where I come from, there isn't such a class with down-draft carbs and no governor control of the engine speed. Good luck. Sure hope you used SP-46 pistons for a good compression ratio. The rods you used are actually shorter in length than a stock OEM rod.
Hudsonator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 8:07am
Where in Tennessee are you?
There isn't much a WC can't do.
WD's just do it better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote big d Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 8:10am
East tn I live in Grainger county which is about 45 above knoxville
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2015 at 9:08am
2bbl holley
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2015 at 3:33pm
Marvel made a 2 barrel side-draft, very small venturis, that went on Massey Ferguson 310 combines equipped with the mopar slant six.
I think we have a couple of them (side draft marvels) around. I'd like to see a picture of that manifold. Seems I did hear of a Heisler intake for a W that used a side-draft carb. Never saw one in person.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2015 at 6:12pm
thought that dr. allis had a manifold with no carb i would like to see a picture also
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2015 at 7:47am
I thought he said he had diesel rods with a offset crank. So what if the diesel rods are a little shorter....maybe the crank throws higher now........or his wrist pin height has changed. Who knows what pistons he is using. Good luck , sir. I CANT JUDGE YOU.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 6:45am
Said he did. I e-mailed him bout' the manifold last week when he mentioned it. Didn't hear from him at all on it....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2015 at 6:59am
I'm curious about your down draft manifold. Something you designed or someone you know designed? If so, what carburetors are the competitors running? Just curious. I like different approaches to high performance modifications being I'm a hotrodder by heart. Makes things interesting. I would think it wouldn't be to tough. My old racing partner and I made a couple sheetmetal intakes for inline Chevy sixes back in the late 60's for a couple customer's Drag Cars we experimented with. One manifold we designed handled two Holley 390 cfm carburetors mounted sideways. The other was a tunnel ram style manifold with a 750 double pumper Holley sittin' on top. The single with the 750 actually worked better. Was a lot of fun experimenting with those. Later Jack Clifford of famous Clifford Research came out with some neat "bolt-on" manifolds for the inlines...
Steve@B&B
This page was generated in 0.172 seconds.
