Just noticed this! Need some engine number help.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Topic: Just noticed this! Need some engine number help.
    Posted: 27 Mar 2010 at 8:48pm
I could have sworn I checked the engine number on my C right after I got it, but apparently not. I was noticing as I was cutting the fuel off that it had a paint run right over it. I got the scraper and wire brush out, cleaned everything up, and lo-and-behold, ITS A DISTILLATE ENGINE!  Never thought that. Remember looking at an engine number, it must have been on my sons' C(his is gas.) engine #BE 62638K. Tractor is a 1946 mod. Wouldn't it have a CE prefix? Got a sneaking feeling it may have an older B engine(116 CI). The tractor has a power unit hood on it, could that engine possibly have come from a power unit? The hood on a B is the same as a C right? Mine has an extra hole in front of the tractor gas tank openning, the hole for the starter tank, and other holes for the exhaust pipe braces. Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:08pm
Bump.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:17pm
Sounds like a B 116 kerosene engine.
What is the casting number AM1234-XX ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:32pm
I'll get back to you. Thanks for the reply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:36pm
What make carburetor and number ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:38pm
Zenith. No number visible. Carb may not match engine anyway.  Let me run out and get casting # from engine. Be right back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:44pm
The carburetor numbers should be on top on a round brass tag. Can be hard to see when the carburetor is on the engine.
You may be lucky and have the original carburetor. #9635  #9805  #9706
Is the BE number you posted from the engine in question?
Edited by Jeff Z. NY - 27 Mar 2010 at 9:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:52pm
Casting# is AM-2916-13. No tag on carb. Had it off when I cleaned it out last April. Yes, BE# is from the engine in my C, which also has a kerosene power unit hood on it. This tractor has apparently been put together from many different sources through the years. Runs good though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:55pm
Casting number from my sons' 1949 C is AM-2916-25. I'm guessing last two digits have something to do with year of manufacture?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:58pm
The casting number chart I have which states to be approx year made shows your number in the 1941 group and the serial number in the 1943 range so who knows.
I would just say an early 1940 BE 116ci kerosene engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 10:09pm
Thanks for the help Jeff. I wonder if anyone would be interested in a trade, or just buying this engine outright. I would really rather have a CE engine for the extra cubes, and a gas engine for a little higher compression. Tractor seemed a little weak when I was pulling the disc harrow with extra weight last summer. Block has a crack approximately 6" long behind the carb. Has been filled with JBweld, doesn't leak any water. No water in oil. Oil pressure runs high on the gauge, and jumps up as soon as she fires off. Needs a new manifold. I brazed the old one to get by. Has new water pump, temp gauge glass is cracked, cant read gauge face, but gauge works. Temp seems to run in the left half of the gauge. Doesn't fluctuate, even when loaded hard in the August heat. Would be a good engine. I just would rather have the right engine for the tractor. Which reminds me, anyone need a hood for a kerosene power unit? Will trade for C hood or sell outright.
Ed in TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed in TX Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 11:48pm
I have a 1941 B that I'm working on. It has a starter tank in the hood but it's not hooked up. Is the engine different than a straight gas tractor? If so can I tell by the engine serial number? Thanks.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 2:25am
Ed
   It's like the guy said. His C engine SN is a BE prefix with a K behind the number (G is Gas) indicating it was not the CE engine used in the C. If the engine was overhauled and fitted with new sleeves and pistons, it is likely they were 3 3/8 standard CE size which would make it a BE on the outside and a CE on the inside.
   The 2 fuel engines had different manifolds. I presume to vaporize kerosene at a higher temp. The two fuel manifold is cast with a opening around the riser tube of the intake and is provided with a shield which partially covers the intake and exhaust parts of the manifold. The Gas manifold is cast solid around the riser tube.
    Engines that were normally handcranked like 60 All Crop engines were equiped with a fresh air cock in the manifold above the carb. By opening the cock to allow entry of fresh air above the carb the tendency of the engine flooding was reduced when cranking a hot engine.
    The parts books show factory motor piston kits available in 6.2:1 Aluminum for Gas or Gas/Kerosene over 6000' alt. - 5.2:1 Al. for Kerosene at high alt. - 4.7:1  cast iron for Kerosene under 3000' -and a 4.75:1 Al for Kerosene. Good luck figuring out what compression ratio pistons you have in what you got.
    Service manuals refer to 5.75:1Gas - 4.75:1Kerosene in the CE engines. and 4.92:1 Gas - 4.67:1 Kerosene in BE engines. In B/C engines Pressures are CE Gas 115 lbs-CE low octane 99lbs. BE Gas 94lbs low octane 84lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 9:15pm
There's honestly no telling what I have until I pull everything down and get the mic. and calipers hold of it. I do know the engine block is from a kerosene B, but the manifold that was on it was for gas. The manifold I have on it right now (robbed from my sons' 49 C) has the brass ballcock valve in the intake above the carb. I don't think it was original to his engine either. Tractor has had a kerosene power unit hood put on it. Lord only knows where that came from. If this tractor could talk, it would probably take all day to explain where all of its' different components came from. LOL!
This page was generated in 0.101 seconds.
