m&w piston prices?
nborga87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Topic: m&w piston prices?
    Posted: 08 Feb 2015 at 1:27am
what is a used set of sp46 m&w pistons worth?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 7:35am
If I was going to purchase a set of real M&W SP-46 pistons and sleeves, I'd be using them with a 4 1/2" stroke crankshaft for a Pulling engine. So, if there's any ring edge groove whatsoever in the sleeves.....they are worth not too much. Then, I assume one would have to buy a new set of rings, so that might be $120 bucks for them ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 7:16pm
thats what i want to use them for. there were some on ebay just the pistons and rods with no sleeves. they ended up selling for $285.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 8:32pm
Nick, I was watching the same set of pistons on Ebay. As a matter of fact, I was the first bidder on them. Here is my thinking on them (right or wrong!).
I'm sure the M&W pistons are better (power wise) than aftermarket flat top pistons BUT the M&W pistons are used (and we don't have any way of knowing how used they are!). You still have to buy a set of gaskets, rings and a set of rod bearings. If your sleeves are good, you can probably get away with honing the sleeves, but I worry about putting M&W pistons in old sleeves since the wrist pin placement is slightly different. If the rings end up higher (or lower) in the sleeve, the wear on the old sleeves could become a problem with different pistons.
Rather than invest close to $300 (plus shipping )in a set of used pistons, I, personally, would rather invest Around $450 in a complete rebuild set like this that includes new sleeves, O rings, rod bearings, main bearings, pistons, rings and most of the gaskets needed to put it back together.
Horsepower might not be quite as high, but I bet longevity would be a lot better.
Just my 2 cents. What do you guys think?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2015 at 9:05pm
I went to $280 on them that would of been $300 with the shipping thats as high as i was going. if i got them i would of got new rings for them and then got a kit like you re talking about. maybe tryed to sell the pistons and rings from the kit. now that i think about it it might be better to just use one of those kits with the flat top pistons and forget the m and w pistons. ill still have a good running engine that i can run on pump gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 6:06am
That's exactly my feelings on it. With a new flat top piston kit, everything is new. They aren't M&W, but it will still increase power over stock.
If you are set on M&W, have you seen the new sleeve/piston/ring kit on Ebay for a "Buy It Now" $735 (plus shipping) ? Too rich for me, but here is the link:
http://www.ebay.com/itm/321631371739?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 8:30am
ive got 6 of those pistons made for wd45 if anybody is interested take 20 apiece for them
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 8:52am
SP-46 or SP-48 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 12:49pm
don't remember the number but they are the shorter version for 4 1/2 crank
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 4:17pm
That should be SP-48 stamped on the inside of the piston.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 8:36pm
Since Nick started this thread, I will step aside and give him first chance. If he doesn't want them, I am definitely interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2015 at 9:25pm
if they are the sp 46 i ll take them. if they are 48s ill pass on them
This page was generated in 0.549 seconds.
