The G runs
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: The G runs
    Posted: 27 Mar 2010 at 11:58am
Brother Jim came over this morning and popped the clutch while I towed him and the G fired right up. It hadn't run in a couple years according to the previous owner so I squirted some PB blaster in each cylinder, cleaned and gapped the plugs, changed points, condenser, and rotor. I removed the starter and found it to be stuck,cleaned the mouse nest out of the flywheel housing, cleaned the air breather and replaced the oil in it. After burning out the PB blaster it ran great. It has great oil pressure,clear up near the L on the gage. I'm still debating on how to work the starter. It's set up now for a push button on the steering support with a toggle on-off switch. I may just uncobble the solenoid set up and use it that way for now. She needs the engine oil changed and then I can start dreaming up a set up for a mower deck.
  Will a G run a 59 inch mower if you don't try to mow tall grass?
Maybe I'd need a supercharger for that big a deck or run in granny gear.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 4:29pm
Ctucker, that's just a great feeling, isn't it? I don't know how large a deck she'll run, but I do know that my G has all it can handle with the multivator that's mounted on there.
WC, CA, D14, WD45
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 6:02pm
It will but you have to run in low gear. My lawn is too large for that. So, my Woods mower is for sale if you're interested. Asking $425. Fall Creek, WI 715-877-1420
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 7:06pm
I have a Woods L59 on the B right now, used to have it on the CA. The B came with a cobbled up mount system and a left hand mower deck that looks almost like the L59. I was just thinking of putting it on for the wife to play with since I told her it was her anniversary present. She won't mind runnin in low. I'll just have to figure out how to mount and power it.
Edited by CTuckerNWIL - 27 Mar 2010 at 7:09pm
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 8:46pm
I bought a G with a Woods 59" finish mower on it and took it off. Too much mower for the little feller. I have another G with a 42" Woods G42 on it and it works just fine. The G42 is a bush hog setup rather than the finish type.
This page was generated in 0.104 seconds.
