m&w piston rings?
nborga87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Topic: m&w piston rings?
    Posted: 29 Jan 2015 at 3:27am
where do you get rings for m&w pistons?
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2015 at 9:08am
i got mine from norm i think hes a vender on here iv seen them in a couple catalogs too measure your ring grooves then match up wich ring package has those size rings in them there was several different ring sizes for the 226. i just did this last summer so u should still be able to get them
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2015 at 1:48pm
do you have his contact info?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2015 at 3:59pm
look under parts venders and its called norms toys
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2015 at 9:14am
The only advertiser I see with the name "Norm" is Norm Meinert at normstractors.com .
Is Norm Meinert the one you are talking about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2015 at 11:13am
Yep that's it
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 7:12am
also available here.  under the PowRseal name
http://www.herschelparts.com/
I called this company regarding questions i had on a NOS M@W set I installed on my 190xt.  They were helpful and had the information i needed.
here is a link to M@W discussion
This page was generated in 0.328 seconds.
