need one piston
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Topic: need one piston
    Posted: 26 Mar 2010 at 4:27pm
I need one piston. Should be for a wd. Piston is marked p24916. Bought a set on ebay, and one of the ring lands was broken, bought another set and they turned out to be a higher compression piston. Hopefully someone can help me out. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 8:22am
if anyone has one i sure would appreciate it
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 9:12am
I dont have a piston but I do have a quetion. I see alot of guys buying used pistons and I often wonder how you guys are getting around a used piston being undersize from originals from years of running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 11:43am
I'm putting it in a power unit that likely will be started once a year to keep it free, and never do any work. Its simply not  worth a $1000 rebuild
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2010 at 1:38pm
I have a set of 4 , 4"  pistons ,with rings and sleeves , I don't want to sell separatly, send a PM if your interested and make an offer.
This page was generated in 0.367 seconds.
