WD45 fornt engine support bolt size
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Topic: WD45 fornt engine support bolt size
    Posted: 22 Jan 2015 at 7:58am
I pulled the motor on my 45 and can't seem to find the correct bolts to bolt the front of the engine to the support. I have two 1/2" bolt left but the won't thread into the holes. I got two new 7/16" bolts and the feel like they might be too small. Does anyone remember what the correct size is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 8:33am
!/2 inch diameter, coarse threads, about 1 inch to 1 1/4" long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 10:41pm
Loosen the motor mount bolts on the side channel, so you can line the holes up, then retighten the side bolts.  They are 1/2-13 threads.  Be sure to shim the front mount per the book, or you will put undue strain on the crankshaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2015 at 7:36am
Thanks guys, I thought for sure they were 1/2. I tried to slide a feeler gauge between the support and mount but even the smallest wouldn't slide between. I assumed this meant I didn't need to shim.
Edited by Allis dave - 23 Jan 2015 at 7:58am
